[Liblas-devel] removal of LASFile from the C++ API
Howard Butler hobu.inc at gmail.com
Fri Jan 29 09:54:40 EST 2010
All,
Consider this your notice that the LASFile class is to be removed from the C++ API for the next release.  It is an ill-considered and poorly designed class, and it does not fit very well with the rest of the API.  If you want a hold-you-hand API for libLAS, use the C API.
Was anyone using this class?
Howard
More information about the Liblas-devel mailing list
