[Liblas-devel] Extract Color from NAIP with python, libLAS, and GDAL
Aaron Reyna aaron.reyna at gmail.com
Thu Jul 22 21:01:35 EDT 2010
Hi all,
I put together this python script to extract color from a NAIP and apply it
to the las file. I can pull out color values from the NAIP, and I scaled
them up to 16 bit, but I seem to be having a problem writing that color
value to file. Actually, everything will come through except the color,
which seems weird. I thought I'd toss it up to the list to see if anyone had
any idea's. Thanks in advance for any suggestions.
Also, keep in mind I have only been writing code about a year. I know, it's
sloppy and slow... but that never stopped me before.
Warmly,
aaron
import os, sys
from liblas import file
from liblas import header
from liblas import color
from liblas import *
try:
  from osgeo import ogr, gdal
  from osgeo.gdalconst import *
  os.chdir('C:\\crap\\county\\Crook')
except ImportError:
  import ogr, gdal
  from gdalconst import *
  os.chdir(r'C:\\crap\\county\\Crook')
print "loaded"
lassy = 'D:\\aaron_working\\DESCHUTTES\\Decluttered_no_birds\\DES_04593.las'
# register all of the GDAL drivers
gdal.AllRegister()
# open the image
img = gdal.Open('naip_1_1_1n_s_or013_2005_1_C4593.img', GA_ReadOnly)
if img is None:
  print 'Could not open aster.img'
  sys.exit(1)
print "loaded img"
# get image size
rows = img.RasterYSize
cols = img.RasterXSize
bands = img.RasterCount
# get georeference info
transform = img.GetGeoTransform()
xOrigin = transform[0]
yOrigin = transform[3]
pixelWidth = transform[1]
pixelHeight = transform[5]
data=file.File(lassy, mode='r')
print "creating .LAS file"
h = header.Header()
h.dataformat_id = 1
h.minor_version = 2
newdata=file.File('D:\\aaron_working\\DESCHUTTES\\Decluttered_no_birds\\DES_04593aaaab.las',
mode='w', header=h)
for p in data:
    pt = point.Point()
    xL = p.x
    yL = p.y
    pt.x = p.x
    pt.y = p.y
    pt.z = p.z
    pt.intensity = p.intensity
    pt.flightline_edge = p.flightline_edge
    pt.scan_flags = p.scan_flags
    pt.number_of_returns = p.number_of_returns
    pt.classification = p.classification
    pt.scan_angle = p.scan_angle
    pt.user_data = p.user_data
    # compute pixel offset
    xOffset = int((xL - xOrigin) / pixelWidth)
    yOffset = int((yL - yOrigin) / pixelHeight)
    # loop through the bands
    for j in range(bands):
        band1 = img.GetRasterBand(1) # 1-based index
        # read data and add the value to the string
        RED = band1.ReadAsArray(xOffset, yOffset, 1, 1)
        band2 = img.GetRasterBand(2)
        GREEN = band1.ReadAsArray(xOffset, yOffset, 1, 1)
        band3 = img.GetRasterBand(3)
        BLUE = band1.ReadAsArray(xOffset, yOffset, 1, 1)
        r16RED = int(RED)* 256
        r16GREEN = int(GREEN) * 256
        r16BLUE = int(BLUE) * 256
        #print r16RED, r16GREEN, r16BLUE
    pt.color = color.Color(r16RED, r16GREEN, r16BLUE)
    newdata.write(pt)
newdata.close()
data.close()
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20100722/45df4680/attachment.html
More information about the Liblas-devel mailing list
