[Liblas-devel] LAS 1.3 point support working for upcoming libLAS 1.6
Howard Butler hobu.inc at gmail.com
Tue Jul 27 10:38:51 EDT 2010
All,
Here's the lasinfo output from Mike's LAS 1.3 file :)  I would not call the 1.3 support "complete" because it has only been tested with one file from one software vendor, but there's nothing blocking us in the code now from 1.3 point support.  Thanks for the file Mike!
If anyone else has some files they can provide for the sample library <http://liblas.org/samples>, I'll give them a test and put them up.
Howard
> fire:data hobu$ lasinfo NERC-ARSF-LAS1_3-sample/LDR100301_120340_4.LAS -c
>   Header Summary
>   File Name: NERC-ARSF-LAS1_3-sample/LDR100301_120340_4.LAS
>   Version:                    1.3
>   Source ID:                  0
>   Reserved:                   0
>   Project ID/GUID:           '00000000-0000-0000-0000-000000000000'
>   System Identifier:         'ALSXX'
>   Generating Software:       'ALSXX_PP V2.70 BUILD#15'
>   File Creation Day/Year:    60/2010
>   Header Size                235
>   Offset to Point Data       5785
>   Number Var. Length Records 5
>   Point Data Format          3
>   Point Data Record Length   57
>   Number of Point Records    1642660
>   Number of Points by Return 1642509 151 0 0 0
>   Scale Factor X Y Z         0.001 0.001 0.001
>   Offset X Y Z               0.000000 5000000.000000 0.000000
>   Min X Y Z                  -235549.276000 5799988.226000 259.047000
>   Max X Y Z                  -234828.416000 5800946.249000 281.244000
>  Spatial Reference
> Geotiff_Information:
>    Version: 1
>    Key_Revision: 1.0
>    Tagged_Information:
>       End_Of_Tags.
>    Keyed_Information:
>       GTModelTypeGeoKey (Short,1): ModelTypeProjected
>       GTRasterTypeGeoKey (Short,1): RasterPixelIsPoint
>       ProjLinearUnitsGeoKey (Short,1): Unknown-32632
>       GeogLinearUnitsGeoKey (Short,1): Linear_Meter
>       VerticalCSTypeGeoKey (Short,1): VertCS_WGS_84_ellipsoid
>       VerticalUnitsGeoKey (Short,1): Linear_Meter
>       End_Of_Keys.
>    End_Of_Geotiff.
>   VLR Summary
>    User: 'LeicaGeo' - Description: 'Intensity Histogram'
>    ID: 1001 Length: 5120
>    User: 'LeicaGeo' - Description: 'MissionInfo'
>    ID: 1002 Length: 22
>    User: 'LeicaGeo' - Description: 'UserInputs'
>    ID: 1003 Length: 54
>    User: 'LASF_Projection' - Description: 'Projection Info'
>    ID: 34735 Length: 56
>    User: 'LASF_Spec' - Description: 'Waveform Data'
>    ID: 100 Length: 26
>   Point Inspection Summary
>   Header Point Count: 1642660
>   Actual Point Count: 1642660
>   Minimum and Maximum Attributes (min,max)
>   Min X,Y,Z: 		-235549.276000,5799988.226000,259.047000
>   Max X,Y,Z: 		-234828.416000,5800946.249000,281.244000
>   Bounding Box:		-235549.28,5799988.23,-234828.42,5800946.25
>   Time:			129850.000003,129864.580506
>   Return Number:	1,2
>   Return Count:		1,2
>   Flightline Edge:	0,1
>   Intensity:		0,255
>   Scan Direction Flag:	0,1
>   Scan Angle Rank:	-28,24
>   Classification:	1,1
>   Point Source Id:	400,414
>   Minimum Color:	 15361 0 0
>   Maximum Color:	 15361 65535 25
> 	(0) 1642509	(1) 151	(2) 0	(3) 0	(4) 0
>  Total Points: 1642660
>   Number of Returns by Pulse
> 	(1) 1642358	(2) 302	(3) 0	(4) 0	(5) 0	(6) 0	(7) 0
>  Total Pulses: 1642660
>   Point Classifications
> 	 1642660 Unclassified (1)
More information about the Liblas-devel mailing list
