[Liblas-devel] Using CMake with gdal and GeoTIFF -> Visual Studio Build Error
Bellinski, Dan Dan.Bellinski at Woolpert.com
Wed Mar 10 11:46:51 EST 2010
Hey Mateusz,
I am using your CMake build with the latest libLAS code and running into
a build error. I am linking libLAS with gdal 1.7.1 trunk and GeoTIFF
1.2.5 (linked with libTIFF 3.9.2). I have successfully built all the
components (other than libLAS) and used the CMake files to create Visual
Studio 2009 project files. All went well in the CMake generation with no
error or warning. When I go to build from the generated VS project
files, Las2ogr and las_c.dll are failing to build. The problematic
output is listed below.
I am unsure where to go with troubleshooting.. do you have any idea what
the problem may be? I made sure my libraries were correct in CMake but
maybe I am missing something? I have the following library/include
variables set up and building in release mode:
GDAL_INCLUDE_DIR:
C:/gdal-1.7.1/port;C:/gdal-1.7.1/frmts/gtiff/libgeotiff;C:/gdal-1.7.1/fr
mts/gtiff/libtiff;C:/gdal-1.7.1/ogr;C:/gdal-1.7.1/gcore;C:/usr/include
GDAL_LIBRARY: C:/gdal-1.7.1/gdal_i.lib
GEOTIFF_INCLUDE_DIR: C:/usr/include
GEOTIFF_LIBRARY: C:/usr/lib/geotiff_i.lib
Any assistance you could lend would be very appreciated. Thanks a lot
for your help!
Dan
3>------ Build started: Project: las_c, Configuration: Release Win32
4>------ Build started: Project: las2ogr, Configuration: Release Win32
3>Compiling...
4>Compiling...
3>las_c_api.cpp
4>las2ogr.cpp
3>C:\libLAS\src\..\include\liblas/lasformat.hpp(111) : warning C4244:
'=' : conversion from 'const liblas::uint32_t' to 'liblas::uint16_t',
possible loss of data
3>..\..\libLAS\src\las_c_api.cpp(210) : warning C4297: 'OpenInput' :
function assumed not to throw an exception but does
3>        The function is extern "C" and /EHc was specified
3>..\..\libLAS\src\las_c_api.cpp(746) : warning C4244: '=' : conversion
from 'unsigned int' to 'liblas::uint16_t', possible loss of data
3>..\..\libLAS\src\las_c_api.cpp(2073) : warning C4800:
'liblas::uint8_t' : forcing value to bool 'true' or 'false' (performance
warning)
3>..\..\libLAS\src\las_c_api.cpp(2074) : warning C4800:
warning)
3>..\..\libLAS\src\las_c_api.cpp(2138) : warning C4800:
warning)
3>..\..\libLAS\src\las_c_api.cpp(2162) : warning C4800:
warning)
4>Linking...
4>   Creating library C:\liblas-Built\bin\Release\Release\las2ogr.lib
and object C:\liblas-Built\bin\Release\Release\las2ogr.exp
4>las.lib(gt_wkt_srs.obj) : error LNK2019: unresolved external symbol
_TIFFGetField referenced in function _GTIFWktFromMemBuf
_TIFFWriteDirectory referenced in function _GTIFMemBufFromWkt
_TIFFWriteCheck referenced in function _GTIFMemBufFromWkt
_TIFFIsTiled referenced in function _GTIFMemBufFromWkt
_TIFFWriteEncodedStrip referenced in function _GTIFMemBufFromWkt
_TIFFSetField referenced in function _GTIFMemBufFromWkt
4>las.lib(tifvsi.obj) : error LNK2019: unresolved external symbol
_TIFFError referenced in function "struct tiff * __cdecl
VSI_TIFFOpen(char const *,char const *)"
(?VSI_TIFFOpen@@YAPAUtiff@@PBD0 at Z)
4>C:\liblas-Built\bin\Release\Release\las2ogr.exe : fatal error LNK1120:
7 unresolved externals
4>Build log was saved at
"file://c:\liblas-Built\apps\las2ogr.dir\Release\BuildLog.htm"
4>las2ogr - 8 error(s), 0 warning(s)
3>Linking...
3>   Creating library C:\liblas-Built\bin\Release\Release\las_c.lib and
object C:\liblas-Built\bin\Release\Release\las_c.exp
3>las.lib(gt_wkt_srs.obj) : error LNK2019: unresolved external symbol
__imp__stricmp referenced in function "void __cdecl WKTMassageDatum(char
* *)" (?WKTMassageDatum@@YAXPAPAD at Z)
3>las.lib(gt_citation.obj) : error LNK2001: unresolved external symbol
__imp__stricmp
__imp__strnicmp referenced in function _GTIFGetOGISDefn
__imp__strnicmp
3>las.lib(tifvsi.obj) : error LNK2019: unresolved external symbol
3>C:\liblas-Built\bin\Release\Release\las_c.dll : fatal error LNK1120: 9
3>Build log was saved at
"file://c:\liblas-Built\src\las_c.dir\Release\BuildLog.htm"
3>las_c - 12 error(s), 7 warning(s)
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20100310/ed78a5c9/attachment.html
More information about the Liblas-devel mailing list
