[Liblas-devel] Using CMake with gdal and GeoTIFF -> Visual Studio Build Error
Dan B Dan.Bellinski at Woolpert.com
Wed Mar 10 14:34:01 EST 2010
To answer your question Howard, when receiving this error I was using the
gdal-1.7.1 stable source from gdal's website. I then built the gdal source
with the external geotiff and tiff library locations in nmake.opt commented
out (so if I understand you correctly it should be using the internal gdal
libraries?).
After reading your response, I tried building gdal with an external tiff
library (tiff-3.9.2 that I also built form source) just to see what would
happen and I received the same error in Visual Studio.
Hopefully this info will help,
Thank you,
Dan
View this message in context: http://n3.nabble.com/Liblas-devel-Using-CMake-with-gdal-and-GeoTIFF-Visual-Studio-Build-Error-tp440103p440394.html
Sent from the libLAS Developers mailing list archive at Nabble.com.
More information about the Liblas-devel mailing list
