[Liblas-devel] Building with cmake/nmake - spatial reference failure
Howard Butler hobu.inc at gmail.com
Wed Mar 17 09:45:03 EDT 2010
On Mar 17, 2010, at 1:14 AM, Wes Toews wrote:
> Thanks Howard that seems to have fixed the problem (whatever it was).  las2las & lasinfo work fine; specifying the srs params though returns this (never mind the switching zones craziness)...
> C:\Liblas\main\test\data>%las%\las2las -v 1.2_2.las srsd.las -s_srs EPSG:26915 -t_srs EPSG:26916
> Unable to import assigned SRS: GeoTIFF ASCII key with no returned size. Upgrade your libgeotiff to a version greater than r1531 (libgeotiff 1.2.6) (3) from method LASSRS_SetFromUserInput
> ...and I thought libgeotiff 1.2.5 was the latest, but it could be me :-)  It's obtained from osgeo anyway yesterday.  I also tried converting to WGS84 (copy-pasting the conversion example in the mailing list earlier) for good riddance with no success
> Thanks in advance,
Yep, we need to issue a new libgeotiff.  I will work with Frank to get 1.3.0 released and on OSGeo4W.  We have already released to release candidates, so it should be a matter of just kicking it out the door.
Howard
More information about the Liblas-devel mailing list
