[Liblas-devel] las2las vertical unit conversion
Brady Callahan brady.callahan at state.or.us
Mon Nov 1 17:10:38 EDT 2010
Is there a way to use las2las to convert or scale Z units? I just used las2las to translate data from EPSG:26910 to EPSG:2992 and it worked fantastic! It took less than 25% of the time that LP360 (GeoCue) does for the same operation! However, my Z units (meters) still need to be converted to international feet. Is that possible with las2las?
Thanks!
~Brady
More information about the Liblas-devel mailing list
