[Liblas-devel] txt2las - adding classification
Howard Butler hobu.inc at gmail.com
Thu Nov 4 09:38:29 EDT 2010
On Nov 4, 2010, at 6:59 AM, Mark Seibel wrote:
> Is there a way with txt2las to put in the .las file that the points
> are a certain class?  It looks like the default is "Created, never
> classified(0)".  I'd like them to be "Ground (2)".
I think you use 'c' to denote classification and then give it a number that represents which class you want.  In this case, 2.
Hope this helps,
Howard
More information about the Liblas-devel mailing list
