[Liblas-devel] Vertical Datum Conversion (Follow Up: Works fine with new liblas release)
Ibraheem Ali ialhakeem at gmail.com
Tue Nov 9 08:50:31 EST 2010
Dear All,
I have downloaded the new release of "libLAS (libLAS 1.6.0b2)" from
"OSGeo4W" and run the vertical datum conversion command as follow:
las2las gal_000052.las --a_srs EPSG:32615 --t_srs EPSG:32615+5703
which basically assign (wgs84, UTM15) coordinate system to the original file
( --a_srs EPSG:32615 ), then transform the vertical datum to NAVD 88 (
--t_srs EPSG:32615+5703).
It worked great, thanks for the great effort.
I have also compared the result with the results from V-datum and they match
to the second decimal place very nicely.(sample calcs. included in this
e-mail).
Thank you very much,
With best regards,
Ibraheem
Below some sample lines from the original file, and the results from liblas,
and V-datum
Original file (WGS 84 UTM15, ellipsoidal height):
293999.95 3219406.51 -25.55
293999.9 3219406.56 -25.53
293999.77 3219406.67 -25.53
293999.72 3219406.71 -25.53
293999.71 3219406.72 -25.51
Liblas Conversion Result  (WGS 84 UTM15, NAVD 88)::
293999.95 3219406.51 0.94
293999.9 3219406.56 0.96
293999.77 3219406.67 0.96
293999.72 3219406.71 0.96
293999.71 3219406.72 0.98
V-Datum Conversion Result (WGS 84 UTM15, NAVD 88):
293999.95 3219406.51 0.9364
293999.9 3219406.56 0.9564
293999.77 3219406.67 0.9564
293999.72 3219406.71 0.9564
293999.71 3219406.72 0.9764
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20101109/9a2c1cdc/attachment.html
More information about the Liblas-devel mailing list
