[Liblas-devel] Fetching color information for LAS files
Howard Butler hobu.inc at gmail.com
Thu Nov 11 16:09:26 EST 2010
All,
I have just implemented a number of options in las2las that allow you to fetch color information from a GDAL-readable raster.  I would like to thank Aaron Reyna for the Autzen_Stadium data that exists on the http://liblas.org/samples sample library that made it easy to test and implement.  This new method in las2las should be considered a replacement for the Python implementation that is available for download if you have a source release of libLAS.
>   --color-source arg       A string to a GDAL-openable raster data source.  Use
>                            GDAL VRTs if you want to adjust the data source or
>                            set its coordinate system, etc.
>                            --color-source "afile.tif"
>   --color-source-bands arg A list of three bands from the --color-source to
>                            assign to the R, G, B  values for the point
>                            --color-source-bands 1 2 3
>   --color-source-scale arg A number used by --color-source to scale the input
>                            R, G, B  values for the point.  For example, to
>                            scale the 8 bit color data from an input raster to
>                            16 bit, the 8 bit data should be multiplied by 256.
>                            --color-source-scale 256
This new functionality will be released in 1.6.0b3.
Howard
More information about the Liblas-devel mailing list
