[Liblas-devel] Cached Reader bottleneck
Mateusz Loskot mateusz at loskot.net
Thu Oct 21 06:54:06 EDT 2010
On 21/10/10 04:39, Gary Huber wrote:
> Mat,
> I got your change and it works to initialize a Reader but on a later
> Reader::Reset() call it runs out of memory. Should it be creating a
> new array on Reset?
In theory, it should not, but I'm not sure what is the context of
resetting the reader. I will have to learn about it.
> At the line cache_mask_type(hptr->GetPointRecordsCount(),
> uncached_mask).swap(m_mask); it throws a std::bad_alloc exception.
This seems to confirm heap fragmentation issue.
Large'ish array exists, reallocation of larger one fails due to lack of
continuous block of requested size.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
More information about the Liblas-devel mailing list
