[Liblas-devel] Cached Reader bottleneck
Mateusz Loskot mateusz at loskot.net
Thu Oct 21 08:00:58 EDT 2010
On 21/10/10 11:54, Mateusz Loskot wrote:
> On 21/10/10 04:39, Gary Huber wrote:
>> Mat,
>> I got your change and it works to initialize a Reader but on a later
>> Reader::Reset() call it runs out of memory. Should it be creating a
>> new array on Reset?
> In theory, it should not, but I'm not sure what is the context of
> resetting the reader. I will have to learn about it.
I forgot about one more thing.
Simply, fetching header like this:
	liblas::Reader reader(ifs);
	header = reader.GetHeader();
causes creation of complete caching engine, including
allocation of masks array. If this array is very large...
Next, running las2las file.las will cause more than (literally 3 or 4)
constructions of LASReader object, thus allocation of the cache masks
array. Long story short, las2las will try to allocate your huge array of
700 millions masks 3 or 4 times! Even if memory is released, subsequent
allocations may simply fail due to fragmentation.
I think we should extract a lightweight LASHeaderReader from LASReader
for uses cases like the above, to avoid setting up complete reading
engine if user wants to get header only.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
More information about the Liblas-devel mailing list
