[Liblas-devel] Need a very large LAS file
David C. Finnegan david.finnegan at usace.army.mil
Wed Oct 27 18:32:54 EDT 2010
All,
If you need something very specific let us know and we can drum something
up. Specifically, it would be good to know if you need rgb, classifications,
etc, etc.
D
On 10/27/10 6:29 PM, "Gary Huber" <gary at garyhuberart.com> wrote:
> Hi Matt,
> I've been using an 18 GB LAS file that I generated using a trial license of
> Safe Software's FME Desktop. I imagine you'd be able to do the same easier
> than I could send you the file. I do get an error in libLAS's cached reader
> system when reading points from that huge file the second time. Somehow it
> seems the istream becomes invalid. I haven't been able to figure out why. It
> reads fine the first time and then part way through the second time when I
> am seeking specific points and then reading a sequence of points that
> follow. The process works fine on smaller files of only a milllion or so
> points.
> -Gary
> http://liblas-developers.431198.n3.nabble.com/Liblas-devel-Need-a-very-large-L
> AS-file-tp1780142p1783187.html
> Sent from the libLAS Developers mailing list archive at Nabble.com.
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20101027/04840602/attachment.html
More information about the Liblas-devel mailing list
