[Liblas-devel] Need a very large LAS file
Black, Michael (IS) Michael.Black2 at ngc.com
Thu Oct 28 08:30:30 EDT 2010
Gary -- can you try using las2las to cut out smaller sections of your file until the problem goes away and find the "magic" point at which it fails?  Actually, I wonder if las2las will even work on a file that large.
That would be enlightening.  I would guess a 32-bit overflow is occurring.
So start, perhaps, at 2GB and keep doubling.
Michael D. Black
Senior Scientist
Advanced Analytics Directorate
Northrop Grumman Information Systems
From: liblas-devel-bounces at lists.osgeo.org on behalf of Gary Huber
Sent: Wed 10/27/2010 5:29 PM
To: liblas-devel at lists.osgeo.org
Subject: EXTERNAL:Re: [Liblas-devel] Need a very large LAS file
Hi Matt,
I've been using an 18 GB LAS file that I generated using a trial license of
Safe Software's FME Desktop. I imagine you'd be able to do the same easier
than I could send you the file. I do get an error in libLAS's cached reader
system when reading points from that huge file the second time. Somehow it
seems the istream becomes invalid. I haven't been able to figure out why. It
reads fine the first time and then part way through the second time when I
am seeking specific points and then reading a sequence of points that
follow. The process works fine on smaller files of only a milllion or so
points.
-Gary
View this message in context: http://liblas-developers.431198.n3.nabble.com/Liblas-devel-Need-a-very-large-LAS-file-tp1780142p1783187.html
Sent from the libLAS Developers mailing list archive at Nabble.com.
Liblas-devel mailing list
Liblas-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20101028/6f7649d7/attachment.html
More information about the Liblas-devel mailing list
