[Liblas-devel] Vertical Datum Transformation
Ibraheem Ali ialhakeem at gmail.com
Sat Oct 30 19:31:59 EDT 2010
Skipped content of type multipart/alternative-------------- next part --------------
C:\galveston_datum_conversion>LASINFO gal_000050.las
  Header Summary
  Version:                     1.2
  Source ID:                   0
  Reserved:                    0
  Project ID/GUID:             '00000000-0000-0000-0000-000000000000'
  System ID:                   ''
  Generating Software:         'TerraScan'
  File Creation Day/Year:      0/0
  Header Byte Size             227
  Data Offset:                 229
  Number Var. Length Records:  None
  Point Data Format:           1
  Number of Point Records:     802804
  Number of Points by Return:  795410 7317 77 0 0
  Scale Factor X Y Z:          0.01 0.01 0.01
  Offset X Y Z:                -0.00 -0.00 -0.00
  Min X Y Z:                   293000.00 3217225.40 -27.13
  Max X Y Z:                   293818.93 3217999.99 -3.60
  Spatial Reference:
Geotiff_Information:
   Version: 1
   Key_Revision: 1.0
   Tagged_Information:
      End_Of_Tags.
   Keyed_Information:
      End_Of_Keys.
   End_Of_Geotiff.
  Schema Summary
  Point Format ID:             1
  Number of dimensions:        13
  Custom schema?:              false
  Size in bytes:               28
  Dimensions
  'X' --  size: 32 offset: 0
  'Y' --  size: 32 offset: 4
  'Z' --  size: 32 offset: 8
  'Intensity' --  size: 16 offset: 12
  'Return Number' --  size: 3 offset: 14
  'Number of Returns' --  size: 3 offset: 14
  'Scan Direction' --  size: 1 offset: 14
  'Flightline Edge' --  size: 1 offset: 14
  'Classification' --  size: 8 offset: 15
  'Scan Angle Rank' --  size: 8 offset: 16
  'User Data' --  size: 8 offset: 17
  'Point Source ID' --  size: 16 offset: 18
  'Time' --  size: 64 offset: 20
  Point Inspection Summary
  Header Point Count: 802804
  Actual Point Count: 802804
  Minimum and Maximum Attributes (min,max)
  Min X, Y, Z:          293000.00, 3217225.40, -27.13,
  Max X, Y, Z:          293818.93, 3217999.99, -3.60,
  Bounding Box:         293000.00, 3217225.40, 293818.93, 3217999.99
  Time:                 512076.970930, 516062.002566
  Return Number:        1, 3
  Return Count:         1, 3
  Flightline Edge:      0, 1
  Intensity:            3, 693
  Scan Direction Flag:  0, 1
  Scan Angle Rank:      -24, 23
  Classification:       1, 9
  Point Source Id:      3, 7
  User Data:            32, 32
  Minimum Color:        0 0 0
  Maximum Color:        0 0 0
        (1) 795410      (2) 7317        (3) 77
  Number of Returns by Pulse
        (1) 788090      (2) 14483       (3) 231
  Point Classifications
        493613 Unclassified (1)
        248639 Ground (2)
        11971 High Vegetation (5)
        48012 Building (6)
        24 Low Point (noise) (7)
        545 Water (9)
        0 withheld
        0 keypoint
        0 synthetic
More information about the Liblas-devel mailing list
