[Liblas-devel] Vertical Datum Transformation
Howard Butler hobu.inc at gmail.com
Sat Oct 30 23:02:48 EDT 2010
On Oct 30, 2010, at 6:31 PM, Ibraheem Ali wrote:
> Hi Frank,
> Thank you very much for the e-mail and the detailed info.
> My data cover Texas coastal region (UTM zone 15), the lasinfo results attached with this e-mail.
> I've tried to run the code line you sent me, but the I always get " Program stopped working" message.
> I tried to assign the coordinate system with -a_srs but again same message.
> Also, I tried the following, trying to figure out what is the problem:
> 1)
> Caption from CMD:
> C:\galveston_datum_conversion> las2las -i gal_000052.las --a_srs
> error message:
> error: required parameter is missing in 'a_srs'
> 2)
> Caption from CMD:
> C:\galveston_datum_conversion> las2las gal_000052.las --a_srs 32615
I think this should be
las2las gal_000052.las --a_srs EPSG:32615 --t_srs EPSG:32615+5703
More information about the Liblas-devel mailing list
