[Liblas-devel] Build Failure in Microsoft Visual C++ 2010
sdellyta at hsr.ch sdellyta at hsr.ch
Fri Apr 15 10:32:25 EDT 2011
I am quite a newbie in this Liblas. I would like to compile Liblas and modified it in order to have a WKT format instead of ASCII.
However, I have several problem while I am building the source code. I am following this link to compile
http://liblas.org/compilation.html#compilation
I am using Window 7. In adition, I am using Boost 1.46.1 and CMake 2.8
Here are the errors that make the build process failed:
1>LINK : fatal error LNK1104: cannot open file 'libboost_thread-vc100-mt-gd-1_46_1.lib'
2>LINK : fatal error LNK1104: cannot open file 'libboost_thread-vc100-mt-gd-1_46_1.lib'
Surprisingly, I can find the .lib in my boost folder. I have no idea why this error can come up.
FYI, I only build the las2txt.
Attached is the detail of error logs.
Any help I'll really appreciate much.
Thank you.
1>------ Build started: Project: liblas, Configuration: Debug Win32 ------
1>libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in indexcell.obj
1>libboost_program_options-vc100-mt-s-1_46_1.lib(config_file.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in indexcell.obj
1>libboost_program_options-vc100-mt-s-1_46_1.lib(convert.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in indexcell.obj
1>libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in indexcell.obj
1>libboost_program_options-vc100-mt-s-1_46_1.lib(cmdline.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in indexcell.obj
1>libboost_program_options-vc100-mt-s-1_46_1.lib(utf8_codecvt_facet.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in indexcell.obj
1>libboost_program_options-vc100-mt-s-1_46_1.lib(value_semantic.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in indexcell.obj
1>libboost_program_options-vc100-mt-s-1_46_1.lib(positional_options.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in indexcell.obj
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: __int64 __thiscall std::ios_base::width(__int64)" (?width at ios_base@std@@QAE_J_J at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: virtual __thiscall std::basic_ios<char,struct std::char_traits<char> >::~basic_ios<char,struct std::char_traits<char> >(void)" (??1?$basic_ios at DU?$char_traits at D@std@@@std@@UAE at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: virtual __thiscall std::basic_ostream<char,struct std::char_traits<char> >::~basic_ostream<char,struct std::char_traits<char> >(void)" (??1?$basic_ostream at DU?$char_traits at D@std@@@std@@UAE at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: __thiscall std::basic_ios<char,struct std::char_traits<char> >::basic_ios<char,struct std::char_traits<char> >(void)" (??0?$basic_ios at DU?$char_traits at D@std@@@std@@IAE at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: virtual __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::~basic_streambuf<char,struct std::char_traits<char> >(void)" (??1?$basic_streambuf at DU?$char_traits at D@std@@@std@@UAE at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: char * __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::gptr(void)const " (?gptr@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IBEPADXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: void __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::setg(char *,char *,char *)" (?setg@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IAEXPAD00 at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: void __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::setp(char *,char *)" (?setp@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IAEXPAD0 at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: char * __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::eback(void)const " (?eback@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IBEPADXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: char * __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::_Pninc(void)" (?_Pninc@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IAEPADXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: void __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::setp(char *,char *,char *)" (?setp@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IAEXPAD00 at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: char * __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::pbase(void)const " (?pbase@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IBEPADXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: char * __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::epptr(void)const " (?epptr@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IBEPADXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: char * __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::pptr(void)const " (?pptr@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IBEPADXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: void __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::gbump(int)" (?gbump@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IAEXH at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: char * __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::egptr(void)const " (?egptr@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IBEPADXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: void __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::pbump(int)" (?pbump@?$basic_streambuf at DU?$char_traits at D@std@@@std@@IAEXH at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "protected: __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::basic_streambuf<char,struct std::char_traits<char> >(void)" (??0?$basic_streambuf at DU?$char_traits at D@std@@@std@@IAE at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: void __thiscall std::basic_ios<char,struct std::char_traits<char> >::setstate(int,bool)" (?setstate@?$basic_ios at DU?$char_traits at D@std@@@std@@QAEXH_N at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: __int64 __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::sputn(char const *,__int64)" (?sputn@?$basic_streambuf at DU?$char_traits at D@std@@@std@@QAE_JPBD_J at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: int __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::sputc(char)" (?sputc@?$basic_streambuf at DU?$char_traits at D@std@@@std@@QAEHD at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: class std::basic_streambuf<char,struct std::char_traits<char> > * __thiscall std::basic_ios<char,struct std::char_traits<char> >::rdbuf(void)const " (?rdbuf@?$basic_ios at DU?$char_traits at D@std@@@std@@QBEPAV?$basic_streambuf at DU?$char_traits at D@std@@@2 at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: char __thiscall std::basic_ios<char,struct std::char_traits<char> >::fill(void)const " (?fill@?$basic_ios at DU?$char_traits at D@std@@@std@@QBEDXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: int __thiscall std::ios_base::flags(void)const " (?flags at ios_base@std@@QBEHXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: __int64 __thiscall std::ios_base::width(void)const " (?width at ios_base@std@@QBE_JXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: class std::basic_ostream<char,struct std::char_traits<char> > & __thiscall std::basic_ostream<char,struct std::char_traits<char> >::flush(void)" (?flush@?$basic_ostream at DU?$char_traits at D@std@@@std@@QAEAAV12 at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: class std::basic_ostream<char,struct std::char_traits<char> > * __thiscall std::basic_ios<char,struct std::char_traits<char> >::tie(void)const " (?tie@?$basic_ios at DU?$char_traits at D@std@@@std@@QBEPAV?$basic_ostream at DU?$char_traits at D@std@@@2 at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: bool __thiscall std::ios_base::good(void)const " (?good at ios_base@std@@QBE_NXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: void __thiscall std::basic_ostream<char,struct std::char_traits<char> >::_Osfx(void)" (?_Osfx@?$basic_ostream at DU?$char_traits at D@std@@@std@@QAEXXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: bool __thiscall std::ios_base::operator!(void)const " (??7ios_base at std@@QBE_NXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: __thiscall std::ios_base::operator void *(void)const " (??Bios_base at std@@QBEPAXXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: bool __thiscall std::basic_istream<char,struct std::char_traits<char> >::_Ipfx(bool)" (?_Ipfx@?$basic_istream at DU?$char_traits at D@std@@@std@@QAE_N_N at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: virtual __thiscall std::basic_iostream<char,struct std::char_traits<char> >::~basic_iostream<char,struct std::char_traits<char> >(void)" (??1?$basic_iostream at DU?$char_traits at D@std@@@std@@UAE at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: __thiscall std::basic_iostream<char,struct std::char_traits<char> >::basic_iostream<char,struct std::char_traits<char> >(class std::basic_streambuf<char,struct std::char_traits<char> > *)" (??0?$basic_iostream at DU?$char_traits at D@std@@@std@@QAE at PAV?$basic_streambuf at DU?$char_traits at D@std@@@1@@Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(options_description.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: int __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::sbumpc(void)" (?sbumpc@?$basic_streambuf at DU?$char_traits at D@std@@@std@@QAEHXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: static unsigned int __cdecl std::numeric_limits<unsigned int>::max(void)" (?max@?$numeric_limits at I@std@@SAIXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(positional_options.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: bool __thiscall std::ctype<char>::is(short,char)const " (?is@?$ctype at D@std@@QBE_NFD at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: int __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::snextc(void)" (?snextc@?$basic_streambuf at DU?$char_traits at D@std@@@std@@QAEHXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: int __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::sgetc(void)" (?sgetc@?$basic_streambuf at DU?$char_traits at D@std@@@std@@QAEHXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: class std::locale __thiscall std::ios_base::getloc(void)const " (?getloc at ios_base@std@@QBE?AVlocale at 2@XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: class std::locale::facet * __thiscall std::locale::facet::_Decref(void)" (?_Decref at facet@locale at std@@QAEPAV123 at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: void __thiscall std::locale::facet::_Incref(void)" (?_Incref at facet@locale at std@@QAEXXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: static unsigned int __cdecl std::ctype<char>::_Getcat(class std::locale::facet const * *,class std::locale const *)" (?_Getcat@?$ctype at D@std@@SAIPAPBVfacet at locale@2 at PBV42@@Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: __thiscall std::locale::id::operator unsigned int(void)" (??Bid at locale@std@@QAEIXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: bool __thiscall std::ios_base::fail(void)const " (?fail at ios_base@std@@QBE_NXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: virtual __thiscall std::basic_istream<char,struct std::char_traits<char> >::~basic_istream<char,struct std::char_traits<char> >(void)" (??1?$basic_istream at DU?$char_traits at D@std@@@std@@UAE at XZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: __thiscall std::basic_istream<char,struct std::char_traits<char> >::basic_istream<char,struct std::char_traits<char> >(class std::basic_streambuf<char,struct std::char_traits<char> > *,bool)" (??0?$basic_istream at DU?$char_traits at D@std@@@std@@QAE at PAV?$basic_streambuf at DU?$char_traits at D@std@@@1 at _N@Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: void __thiscall std::basic_ios<char,struct std::char_traits<char> >::clear(int,bool)" (?clear@?$basic_ios at DU?$char_traits at D@std@@@std@@QAEXH_N at Z) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
1>msvcprtd.lib(MSVCP100D.dll) : error LNK2005: "public: void __thiscall std::basic_istream<char,struct std::char_traits<char> >::`vbase destructor'(void)" (??_D?$basic_istream at DU?$char_traits at D@std@@@std@@QAEXXZ) already defined in libboost_program_options-vc100-mt-s-1_46_1.lib(parsers.obj)
2>------ Build started: Project: las2txt, Configuration: Debug Win32 ------
2>  las2txt.cpp
2>  laskernel.cpp
2>  Generating Code...
========== Build: 0 succeeded, 2 failed, 1 up-to-date, 0 skipped ==========
More information about the Liblas-devel mailing list
