[Liblas-devel] tackling the root of inefficiency, with Parallel Python, LAStools
Aaron Reyna aaron.reyna at gmail.com
Sat Apr 16 14:36:17 EDT 2011
OK, sorry for the cross post with the LAStools mailing list, but I thought
this was kind of important. Not directly liblas, but close enough.
All,
been so busy as of late with a new job that I haven't had time to post this
simple combination of parallel python and LAStools. Wrote it on a plane to
germany, so it only is set to SMP, but it could easily be dumped across a
system with several hundred nodes. Ah, I love python.
import pp, time
# Import system modules
import sys, string, os
def text_blaster(s):
    com = "C:/OSGeo4W/bin/las2txt.exe -i C:/projects/SB/input/SBEX_41.las -o
C:/projects/SB/output/" + s
    app_run = str(com)
    z = os.system(app_run)
my_list = ["SBEX_41.txt", "SBEX_41_2.txt", "SBEX_41_3.txt", "SBEX_41_4.txt",
"SBEX_41_5.txt", "SBEX_41_6.txt", "SBEX_41_7.txt", "SBEX_41_8.txt",]
print """Usage: python test_SMP.py [ncpus]
    [ncpus] - the number of workers to run in parallel,
    if omitted it will be set to the number of processors in the system
# tuple of all parallel python servers to connect with
ppservers = ("*",)
if len(sys.argv) > 1:
    ncpus = int(sys.argv[1])
    # Creates jobserver with ncpus workers
    job_server = pp.Server(ncpus, ppservers=ppservers)
else:
    # Creates jobserver with automatically detected number of workers
    job_server = pp.Server(ppservers=ppservers)
start_time = time.time()
print "Starting pp with", job_server.get_ncpus(), "workers"
for process in my_list:
    job1 = job_server.submit(text_blaster, (process,))
print "Time elapsed: ", time.time() - start_time, "s"
result = job1()
#print "CLUSTER TEST is", result
# Submitted jobs and retrieved results
job_server.print_stats()
RESULTS:-------------------------------------------------------------------------------------------------------------------------------
Starting pp with 1 workers
Time elapsed:  0.00399994850159 s
Time elapsed:  60.1719999313 s
Job execution statistics:
 job count | % of all jobs | job time sum | time per job | job server
         8 |        100.00 |      60.1650 |     7.520625 | local
Time elapsed since server creation 60.1719999313
Starting pp with 4 workers
Time elapsed:  0.00999999046326 s
Time elapsed:  27.8439998627 s
         8 |        100.00 |      82.2060 |    10.275750 | local
Time elapsed since server creation 27.8459999561
Used one las file, 500 meters by 500 meters, 30pts per square meter. Time
was cut in half. Well, less than half.
Cheers,
Aaron
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110416/e97ed956/attachment.html
More information about the Liblas-devel mailing list
