[Liblas-devel] LASzip versus LT compressor
Michael P. Gerlek mpg at flaxen.com
Wed Apr 27 11:28:21 EDT 2011
Martin, can you give the data below in terms of compression ratio against
the original file sizes?
Also, are you willing to report the timing data?
-mpg
[mailto:liblas-devel-bounces at lists.osgeo.org] On Behalf Of Martin Isenburg
Sent: Wednesday, April 27, 2011 8:12 AM
To: liblas-devel at lists.osgeo.org
Subject: [Liblas-devel] LASzip versus LT compressor
Hello,
People sometimes ask me how LASzip compares to the LIDAR compressor from
Lizard Tech and I usually refer them to Michael's email (see below). Because
his benchmarking was wrong on one model, namely MG4 does not outperform
LASzip on 2398_400.las, i did my own experiments that suggest that LASzip
compresses about 35% better and is faster.
A set of 27 LAS files (see below for a listing) compresses to 403 MB with
LASzip and to 610 MB with the LIDAR compressor from Lizard Tech.
A 1.7GB LAS file of a flight swath (see below for the details) compresses to
352 MB with LASzip and to 648 MB with the LIDAR compressor from Lizard Tech.
LASzip encoding is about 10 times faster. LASzip decoding is about 3 times
faster. timings measurements included all disk I/O from compressed file to
uncompressed file (and vice-versa) using two separate drives. disclaimer:
the LASzip compressor is tuned for LAS files that contain LIDAR in
acquisition order.
Cheers,
martin @lastools
the list of 27 LAS files. the first number is the compressed file size in
bytes for the LIDAR Compressor of Lizardtech. the second number is the
compressed file size in bytes for LASzip. all files can be found here
http://liblas.org/samples except "Dallas.las" and "Tetons.las" which are
here: http://bin.us.lizardtech.com/lidar/LT_LiDAR_Sample_Data.zip
115,857,121    61,809,700     autzen-colorized-1.2-3.las
37,462,947    14,881,473     Dallas.las
18,035,893    17,128,065     GrassLakeSmall.las
48,947,417    19,621,507     IowaDNR-CloudPeakSoft-1.0-UTM15N.las
15,248,628    13,382,538     LAS12_Sample_withRGB_QT_Modeler.las
11,222,840    10,444,300     LASFile_1.las
9,805,767    9,154,780     LASFile_2.las
3,966,869    3,665,433     LASFile_3.las
10,691,410    9,940,731     LASFile_4.las
13,522,405    12,672,774     LDR030828_212242_0.las
13,058,811    12,157,072     LDR030828_213023_0.las
12,244,190    11,502,895     LDR030828_213450_0.las
19,820,246    10,414,626     LDR091111_181233_1.las
19,424,894    10,193,907     LDR091111_182803_1.las
30,451,604    28,680,682     Lincoln.las
27,076,520    28,593,056     line_27007_dd.las
25,753,118    19,594,207     MARS_Sample_Filtered_LiDAR.las
19,820,246    10,414,626     merrick_vertical_1.2.las
8,943,713    9,493,209     MountStHelensNov202004.las
20,937,807    20,337,536     MountStHelensOct42004.las
20,386,038    19,036,134     ncwc000008.las
7,900,248    7,539,341     PalmBeachPreHurricane.las
22,831,603    9,920,385     S1C1_strip021.las
28,006,302    10,036,738     SerpentMoundModelLASData.las
37,216,167    18,169,153     Tetons.las
34,980,891    18,961,597     USACE_Merrick_lots_of_VLRs.las
5,756,508    5,351,794     xyzrgb_manuscript.las
the lasinfo details of the 1.7GB LAS file containing one swath
lasinfo Ldr100402_220229_1.laz
reporting all LAS header entries:
  file signature:            'LASF'
  file source ID:            0
  reserved (global_encoding):0
  project ID GUID data 1-4:  0 0 0 ''
  version major.minor:       1.0
  system identifier:         'ALSXX'
  generating software:       'ALSXX_PP V2.69 BUILD#7 BETA'
  file creation day/year:    92/2010
  header size                227
  offset to point data       5697
  number var. length records 4
  point data format          1
  point data record length   28
  number of point records    66705904
  number of points by return 58445315 6743224 1404140 113225 0
  scale factor x y z         0.001 0.001 0.001
  offset x y z               13000000 0 0
  min x y z                  12991192.425 588397.501 611.122
  max x y z                  13142242.349 594146.283 3032.417
variable length header record 1 of 4:
  reserved             43707
  user ID              'LeicaGeo'
  record ID            1001
  length after header  5120
  description          ''
variable length header record 2 of 4:
  reserved             43707
  user ID              'LeicaGeo'
  record ID            1002
  length after header  22
  description          'MissionInfo'
variable length header record 3 of 4:
  reserved             43707
  user ID              'LeicaGeo'
  record ID            1003
  length after header  54
  description          'UserInputs'
variable length header record 4 of 4:
  reserved             43707
  user ID              'LASF_Projection'
  record ID            34735
  length after header  56
  description          'Projection Info'
    GeoKeyDirectoryTag version 1.1.0 number of keys 6
      key 1024 tiff_tag_location 0 count 1 value_offset 1 -
GTModelTypeGeoKey: ModelTypeProjected
      key 1025 tiff_tag_location 0 count 1 value_offset 2 -
GTRasterTypeGeoKey: RasterPixelIsPoint
      key 3076 tiff_tag_location 0 count 1 value_offset 26990 -
ProjLinearUnitsGeoKey: look-up for 26990 not implemented
      key 2052 tiff_tag_location 0 count 1 value_offset 9002 -
GeogLinearUnitsGeoKey: Linear_Foot
      key 4096 tiff_tag_location 0 count 1 value_offset 5103 -
VerticalCSTypeGeoKey: VertCS_North_American_Vertical_Datum_1988
      key 4099 tiff_tag_location 0 count 1 value_offset 9002 -
VerticalUnitsGeoKey: Linear_Foot
the header is followed by 2 user-defined bytes
LASzip compression (version 1.0r0 c1): POINT10 1 GPSTIME11 1
reporting minimum and maximum for all LAS point record entries ...
  x -8807574 142242349
  y 588397501 594146283
  z 611122 3032417
  intensity 0 255
  edge_of_flight_line 0 0
  scan_direction_flag 0 1
  number_of_returns_of_given_pulse 1 4
  return_number 1 4
  classification 1 1
  scan_angle_rank -26 31
  user_data 161 255
  point_source_ID 161 511
  gps_time 511349.016753 512063.402540
overview over number of returns of given pulse: 51686151 10678566 3886669
454518 0 0 0
histogram of classification of points:
 66705904 Unclassified (1)
michael's email (the graphs he mentions can be found in the archive)
http://lists.osgeo.org/pipermail/liblas-devel/2011-February/001199.html
On Fri, Feb 4, 2011 at 3:21 PM, Michael Rosen <mrosen at lizardtech.com> wrote:
Here's the summary of some LT-internal (I guess not so internal now.)
benchmarking.  Highlights:
-          I can't really draw any conclusions about relative compression
sizes:  2398_400 favors MG4 2:1, HGAC_Extract and AutZen favor LAZ 2:1,
MtStHelens is a wash,
-          WRT extraction time, for smaller files, the MG4's computational
overhead (*) favors LAZ for all but the smallest extractions
-          For larger files, the "break even" point is much further to the
right.
-          For larger files, with very small extractions, the built-in index
of MG4 allows faster extractions than raw (unindexed) LAS.
The methodology here was to run "las2las" as shown before cropping out
increasingly large rectangles (at full resolution)
I compared this with the same extraction from MG4 using a command line tool
(internal) but this time, writing the output to a las file.
I spot checked that the number of points written in all three cases was the
same.
(*) Note that the title on the graphs is not quite right.  It's not "Decode
Time" but "Decode Time plus LAS Write Time" vs Scene Size.  There is some
speculation (based on what we were observing when omitting the output) that
LT's LAS Writer is unusually slow.  It's using the liblas v1.2 writer . so
some here may have well-informed opinions on this.
Here is some raw data and some graphs:
01/28/2011  03:50 PM        61,301,311 2398_400.las
01/28/2011  04:28 PM         8,906,275 2398_400.laz
01/28/2011  04:25 PM         4,650,992 2398_400.sid
01/28/2011  04:03 PM       362,213,959 autzen-colorized-1.2-3.las
01/28/2011  04:28 PM        61,809,700 autzen-colorized-1.2-3.laz
01/28/2011  04:27 PM       115,857,121 autzen-colorized-1.2-3.sid
01/28/2011  03:59 PM       123,876,781 Grass Lake Small.las
01/28/2011  04:29 PM        17,128,065 Grass Lake Small.laz
01/28/2011  04:25 PM        18,035,893 Grass Lake Small.sid
02/02/2011  08:18 AM       711,065,603 HGAC_Extract.las
02/02/2011  08:23 AM       151,159,393 HGAC_Extract.laz
02/02/2011  08:29 AM       269,491,108 HGAC_Extract.sid
01/28/2011  03:50 PM        34,065,751 hobu.las
01/28/2011  04:29 PM         7,732,878 hobu.laz
01/28/2011  04:24 PM         9,301,431 hobu.sid
01/28/2011  04:00 PM       185,565,975 Lincoln.las
01/28/2011  04:29 PM        28,680,682 Lincoln.laz
01/28/2011  04:25 PM        30,451,604 Lincoln.sid
01/28/2011  03:58 PM       107,603,879 line_27007.las
01/28/2011  04:30 PM        22,269,252 line_27007.laz
01/28/2011  04:25 PM        24,588,596 line_27007.sid
01/28/2011  03:58 PM       115,737,877 MtStHelens.las
01/28/2011  04:30 PM         9,493,209 MtStHelens.laz
01/28/2011  04:24 PM         8,943,713 MtStHelens.sid
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110427/92129ece/attachment-0001.html
More information about the Liblas-devel mailing list
