[Liblas-devel] Written file can't be read by other .las viewers
Martin Isenburg martin.isenburg at gmail.com
Fri Aug 26 15:53:06 EDT 2011
hi,
to have a "proper" LAS file you should set the
number_of_returns_of_given_pulse and the return_number of each point (see
the reamining warnings of lasinfo).
if you have one return per pulse ... set them both to 1.
and i guess i should put something into lasview that automatically detects
it when the bounding box is set to 0 0 0 / 0 0 0 and then computes it on the
fly ...
cheers,
martin
On Fri, Aug 26, 2011 at 12:39 PM, James Hargrave <jhargrave at photomodeler.com
> wrote:
> Hey guys,
> Thanks for the suggestions and help.  Running the repair gave me the clue I
> needed.  I wasn't setting the min/max values to the header.
> Here's the output from the repair:
> reporting all LAS header entries:
>  file signature:            'LASF'
>  file source ID:            0
>  reserved (global_encoding):0
>  project ID GUID data 1-4:  0 0 0 ''
>   version major.minor:       1.2
>  system identifier:         'libLAS'
>  generating software:       'libLAS 1.7.0b2'
>  file creation day/year:    237/2011
>  header size                227
>  offset to point data       227
>   number var. length records 0
>   point data format          3
>  point data record length   34
>  number of point records    5857
>  number of points by return 0 0 0 0 0
>   scale factor x y z         0.01 0.01 0.01
>  offset x y z               0 0 0
>   min x y z                  0.00 0.00 0.00
>  max x y z                  0.00 0.00 0.00
> reporting minimum and maximum for all LAS point record entries ...
>   x -1323 1581
>  y -831 983
>  z -3855 -1905
>  intensity 0 0
>   edge_of_flight_line 0 0
>  scan_direction_flag 0 0
>  number_of_returns_of_given_pulse 0 0
>  return_number 0 0
>  classification 0 0
>  scan_angle_rank 0 0
>  user_data 0 0
>  point_source_ID 0 0
>   gps_time 0.000000 0.000000
>  Color R 0 220
>        G 1 243
>        B 0 255
> WARNING: there are 5857 points with return number 0
> WARNING: there are 5857 points with a number of returns of given pulse of 0
> histogram of classification of points:
>      5857 Created, never classified (0)
> real max x larger than header max x by 15.810000 (repaired)
> real min x smaller than header min x by 13.230000 (repaired)
> real max y larger than header max y by 9.830000 (repaired)
> real min y smaller than header min y by 8.310000 (repaired)
> real min z smaller than header min z by 38.550000 (repaired)
> I added these lines after writing all the points (and computing the min/max
> during the write):
>        header.SetMin( min.X(), min.Y(), min.Z() );
>        header.SetMax( max.X(), max.Y(), max.Z() );
>        writer->SetHeader(header);
>        writer->WriteHeader();
> This fixed the problem.
> Are there any other fields I should be specifically setting?
> Heaps of thanks,
> - James
> > -----Original Message-----
> > From: Howard Butler [mailto:hobu.inc at gmail.com]
> > Sent: August-26-11 6:33 AM
> > To: James Hargrave
> > Cc: liblas-devel
> > Subject: Re: [Liblas-devel] Written file can't be read by other .las
> > viewers
> > On Aug 26, 2011, at 8:11 AM, Howard Butler wrote:
> > > On Aug 25, 2011, at 6:16 PM, James Hargrave wrote:
> > >> Hello,
> > >> When I use laslib to create a file I am able to then read the file
> back
> > in
> > >> and everything seems fine.  However, I am unable to view the file in
> > other
> > >> applications such as the lasview.exe utility found here:
> > >> http://www.cs.unc.edu/~isenburg/lastools/
> > >> The steps I use mirror the C++ tutorial from the laslib.org site:
> > >>    ofs.open((char*)filename, ios::out | ios::binary);
> > >>    liblas::Header header;
> > >>    writer = new liblas::Writer(ofs, header);
> > >> Then in a loop:
> > >>    liblas::Point point;
> > >>    point.SetCoordinates(pt.X(), pt.Y(), pt.Z());
> > >>    // fill other properties of point record
> > >>    if ( rgb )
> > >>            point.SetColor( liblas::Color( rgb[0], rgb[1], rgb[2] ) );
> > >>    writer->WritePoint(point);
> > >> If anyone has any ideas I'd appreciate any suggestions.  If it would
> > help I
> > >> can also provide a sample output file which I am able to read back in
> > using
> > >> liblas but does not appear when loaded into lasview.exe .
> > >> Thanks,
> > >> - James
> > > James,
> > > Which version of libLAS are you using? The following just worked for me
> > this morning with the latest git HEAD on
> https://github.com/libLAS/libLAS
> > > ~/liblas$ las2las TO_core_last_zoom.las lastools-test-from-liblas.las
> > > ~/lastools/bin/lasinfo lastools-test-from-liblas.las
> > >>  file source ID:            0
> > >>  version major.minor:       1.0
> > >>  system identifier:         ''
> > >>  generating software:       'TerraScan'
> > >>  file creation day/year:    0/0
> > >>  header size                227
> > >>  offset to point data       229
> > >>  point data format          1
> > >>  point data record length   28
> > >>  number of point records    213093
> > >>  number of points by return 128621 84472 0 0 0
> > >>  offset x y z               -0 -0 -0
> > >>  min x y z                  630250.00 4834500.00 46.83
> > >>  max x y z                  630500.00 4834750.00 170.65
> > >> the header is followed by 2 user-defined bytes
> > >>  x 63025000 63050000
> > >>  y 483450000 483475000
> > >>  z 4683 17065
> > >>  intensity 10 50200
> > >>  number_of_returns_of_given_pulse 1 2
> > >>  return_number 1 2
> > >>  classification 1 1
> > >>  scan_angle_rank 0 0
> > >>  user_data 2 4
> > >>  point_source_ID 0 0
> > >>  gps_time 413162.560400 414095.322000
> > >> overview over number of returns of given pulse: 128621 84472 0 0 0 0 0
> > >>   213093 Unclassified (1)
> > > Are you making sure to delete the writer in your code? You must delete
> > the writer because it will be writing header details at the end of
> writing.
> > Also, make sure to do ofs.close() to force the flush of any data left in
> > the ostream buffer.
> > After some discussion on IRC with Martin, he suggested you run the
> > following:
> > ~/lastools $ lasinfo -repair file-written-by-liblas.las
> > I don't think your code is updating the header's bounds and return count
> > information, and this might be required for lasview.exe to run.
> > Howard
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110826/da699308/attachment-0001.html
More information about the Liblas-devel mailing list
