[Liblas-devel] lasinfo: error while loading shared libraries
Eric Goddard egoddard at memphis.edu
Sat Feb 19 11:50:10 EST 2011
Hello everyone,
I am trying to load some lidar data with grass/QGIS. Following the
compilation instructions at http://liblas.org/compilation.html, I have
successfully compiled and installed LibLAS1.6.0 on Linux Mint 10 (Ubuntu
10.10) with GDAL support to /usr/local.
whenever I run
     lasinfo -c ~/Downloads/S1980745.las
I get the following error message:
lasinfo: error while loading shared libraries: liblas.so.2.0.0: cannot open
shared object file: No such file or directory
This error occurs when running any of the las* tools, though liblas-config
will correctly output its version.
My /usr/local/lib directory contains the following liblas related files:
liblas_c.so        liblas.so
liblas_c.so.2.0.0  liblas.so.2.0.0
so I am not sure why is saying that it cannot find the files.
Any insight into this issue would be greatly appreciated.
Thanks,
Eric
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110219/f5c1ccf0/attachment.html
More information about the Liblas-devel mailing list
