[Liblas-devel] lasinfo: error while loading shared libraries
Volker Wichmann wichmann at laserdata.at
Sat Feb 19 12:55:04 EST 2011
Please always reply to the list, I'm forwarding your reply.
-------- Original Message --------
Subject: 	Re: [Liblas-devel] lasinfo: error while loading shared libraries
Date: 	Sat, 19 Feb 2011 11:19:31 -0600
To: 	Volker Wichmann <wichmann at laserdata.at>
I did not. That fixed it. Thanks, Volker!
On Sat, Feb 19, 2011 at 10:59 AM, Volker Wichmann <wichmann at laserdata.at
<mailto:wichmann at laserdata.at>> wrote:
     Hi Eric,
     did you run /sbin/ldconfig in order to configure dynamic linker run
     time bindings?
     Best regards,
     Volker
     On 02/19/2011 05:50 PM, Eric Goddard wrote:
         Hello everyone,
         I am trying to load some lidar data with grass/QGIS. Following the
         compilation instructions at http://liblas.org/compilation.html,
         I have
         successfully compiled and installed LibLAS1.6.0 on Linux Mint 10
         (Ubuntu
         10.10) with GDAL support to /usr/local.
         whenever I run
               lasinfo -c ~/Downloads/S1980745.las
         I get the following error message:
         lasinfo: error while loading shared libraries: liblas.so.2.0.0:
         cannot
         open shared object file: No such file or directory
         This error occurs when running any of the las* tools, though
         liblas-config will correctly output its version.
         My /usr/local/lib directory contains the following liblas
         related files:
         liblas_c.so        liblas.so
         liblas_c.so.2.0.0  liblas.so.2.0.0
         so I am not sure why is saying that it cannot find the files.
         Any insight into this issue would be greatly appreciated.
         Thanks,
         Eric
         Liblas-devel mailing list
         Liblas-devel at lists.osgeo.org <mailto:Liblas-devel at lists.osgeo.org>
         http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
