[Liblas-devel] change the vertical datum WGS84 to NAVD88 and transformation method?
Ibraheem Ali ialhakeem at gmail.com
Tue Jul 26 13:33:06 EDT 2011
Dear All,
I would like to ask you kindly to let me know which geoid is used when
converting from WGS84 to NAVD88?
Also, what transformation method (e.g. 7 parameter transformation?) is used
when transform the coordinates?
Thank you very much
Ibraheem
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110726/11b139a0/attachment.html
More information about the Liblas-devel mailing list
