[Liblas-devel] Point Scale/Offset Behavior, Possible Bug.
Black, Tim tblack at ball.com
Fri Jun 17 10:24:57 EDT 2011
On a quick side note, what is the procedure for submitting bug reports? I went to the "Bugs" link, but I couldn't see a way to submit without being able to log in to the site.
While working on modifying (Mainly reprojection and conversion of units) some point data, I came across some odd behavior. First, I would read the data in from File A and make any adjustments required. Next, I would write the file out to File B with updated header information. However, when I subsequently read the data in from File B, the values would be incorrect. After some trial and error, I realized that the problem was with differences in the offset and scale in the headers of File A and File B. Normally, the point data is stored with the scale and offset applied. When a new header is assigned to the pointer, it should be updated to reflect the new values. However, looking at the point.cpp code, it looks as though the data is only updated if the point format(And subsequently, the size of the point data) is changed. Otherwise, it returns before reaching the code that updates the coordinates. The section of code below is taken from line 366+ of the point.cpp class. I am currently running 1.6.1, but it also appears that the problem will still occur in the current trunk.(I have not built and tested the latest version, so I can't say for certain) The problem occurs in the else block of code. If the point format is the same but the offset has changed, the return there prevents the XYZ coordinates from being updated with the new offset.
[After determining data size of new header]
if (wanted_length != m_data.size())
        // Manually copy everything but the header ptr
        // We can't just copy the raw data because its
        // layout is likely changing as a result of the
        // schema change
      [Snipped copying of metadata for space]
    } else
        m_header_new = header;
        return;
    double x;
    double y;
    double z;
    if (bSetCoordinates)
        x = GetX();
        y = GetY();
        z = GetZ();
    // The header's scale/offset can change the raw storage of xyz.
    // SetHeaderPtr can result in a rescaling of the data.
        SetX(x);
        SetY(y);
        SetZ(z);
Tim Black
Ball Aerospace
571-357-2158
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110617/080f69d4/attachment.html
More information about the Liblas-devel mailing list
