[Liblas-devel] IDE used/good for using Liblas
thejus kambi thejus.kambi at gmail.com
Wed Jun 22 09:40:33 EDT 2011
hmm, I am using Window.
On Wed, Jun 22, 2011 at 3:32 PM, Ivan Lucena <ivan.lucena at pmldnet.com>wrote:
> Thejus,
> If ( OS != Win )
>  netbeans.org
> See example of how to set it up:
> http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithNetBeansIDE
> All it does is to parse your C/C++ code in order to do auto-completion,
> goto definition, find usage, refactoring and things like that. You don't to
> create a project definition because it will use the original makefiles. You
> can also use netbeans as a SVN, CVS or Mercurial front-end. For debugging it
> will use the GDB installed in your system.
> Regards,
> Ivan
> >  -------Original Message-------
> >  From: thejus kambi <thejus.kambi at gmail.com>
> >  To: liblas-devel at lists.osgeo.org
> >  Subject: [Liblas-devel] IDE used/good for using Liblas
> >  Sent: Jun 22 '11 08:01
> >  Hello,
> >  It could be a very basic question, Please bear with me, I am new to c++.
> >  Could you suggest me a good IDE for using liblas?
> >  Thanks in advance,
> >  Thejus
> >  _______________________________________________
> >  Liblas-devel mailing list
> >  [LINK: compose.php?to=Liblas-devel at lists.osgeo.org]
> >  [LINK: http://lists.osgeo.org/mailman/listinfo/liblas-devel]
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110622/98c7afb0/attachment.html
More information about the Liblas-devel mailing list
