[Liblas-devel] Ground Modeling with RAW LiDAR and libLAS
Stuart Edwards sedwards2 at cinci.rr.com
Fri Mar 4 10:07:55 EST 2011
I don't find it to be particularly slow .... I guess it depends on how much processing you have to do.  My uses are fairly limited so it's not a problem.
Not quite on topic, but close, and something I'm trying to figure out -- the LibLAS decoded file can provide all of the point data - not just x,y,z.  This includes identification of 1st and 2nd arrivals which helps a lot in discerning vegetal cover from the ground surface.
However, if you are going to filter on arrival time to get a ground surface data set you have to eliminate the 1st arrivals - but only if there's a second. If a second is absent (no vegetation at that location) then the 1st becomes the 'last' too.  This makes interpretation more complicated and not just a matter of separating the 1s and 2s.  I ended up writing a short script in octave to split the data into two pools - first arrivals and true last arrivals using the simple notion that a 1 is only a first if it is followed by a 2.  If not, it's a last.
 Has anyone else wrestled with this?
Stu
On Mar 4, 2011, at 9:29 AM, francesco wrote:
> I use GRASS quite a lot, but always thought that it would be slow on vector points. I know Brovelli and her team developed some modules, I'll check on that. Good idea to use LibLAS as "driver" to turn LAS to xyz.
> Francesco
> Il 04/03/2011 15:05, Stuart Edwards ha scritto:
>> GRASS GIS (open source) has several modules for processing raw LiDAR data and the ability to script your own classification routines.  LibLAS does a nice job of preprocessing (decoding) the LAS files so they can be input to GRASS as x,y,z or general ASCII format .......see:
>>  http://grass.osgeo.org/wiki/LIDAR#Micro-tutorial
>> Stu
>> On Mar 4, 2011, at 1:31 AM, francesco wrote:
>>> Hello List,
>>> I just registered, hello to everyone.
>>> Regarding Aaron's question, I am playing around with LibLAS to develop a ground classification procedure. It uses Axellson's progressive triangulation of local minimum points - but I am also looking at other solutions. Does anyone have other interesting approaches in mind?
>>> Cheers,
>>> Francesco
>>> Francesco Pirotti
>>> Dep. TESAF
>>> CIRGEO – Interdepartmental Research Center on Cartography Photogrammetry
>>> Remote Sensing and G.I.S.
>>> University of Padova
>>> Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
>>> Email: francesco.pirotti at unipd.it
>>> Phone: +39 049 827 2710
>>> Phone: +39 349 55 39 261
>>> Il 04/03/2011 00:49, Aaron Reyna ha scritto:
>>>> Ah yes,
>>>> I'll try the MCC-LiDAR. Great, thanks for the suggestion!
>>>> Aaron
>>>> On Thu, Mar 3, 2011 at 3:09 PM, Peter Tittmann <pwtittmann at ucdavis.edu> wrote:
>>>> I've used MCC-Lidar http://sourceforge.net/apps/trac/mcclidar/ a little with marginal results. Not a great answer but something. TeraScan http://www.terrasolid.fi/en/products/terrascan is the elephant in that room.
>>>> Peter
>>>> On 03/03/2011 02:43 PM, Aaron Reyna wrote:
>>>>> This may be too broad of a question, but has anyone seen or heard of a way to do efficient ground modeling with libLAS? That is, take raw LiDAR files (all default points) and model out the ground class? I do have raw LiDAR files if                               it helps.
>>>>> Just throwing it out there.
>>>>> Best,
>>>>> Aaron
>>>>> _______________________________________________
>>>>> Liblas-devel mailing list
>>>>> Liblas-devel at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/liblas-devel
>>>> Peter Tittmann
>>>> Geography Graduate Group
>>>> UC Davis
>>>> c. 707 849 4135
> Francesco Pirotti
> Dep. TESAF
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110304/85f7e9f0/attachment-0001.html
More information about the Liblas-devel mailing list
