[Liblas-devel] Header::SetDataFormatId, and supported schemas
Howard Butler hobu.inc at gmail.com
Mon Mar 7 11:02:09 EST 2011
On Mar 6, 2011, at 8:53 AM, Martin Isenburg wrote:
> hi ben.
>> ePointFormat0: has dimensions "X, Y, Z, Intensity, Return Number,
>> Number of Returns, Scan Direction, Flightline Edge, Classification,
>> Scan Angle Rank, User Data, Point Source ID".
>> ePointFormat1: all of those, plus it adds "Time".
>> ePointFormat2: adds Color ("Red", "Green", "Blue")
>> ePointFormat3: adds "Time" and Color.
>> ePointFormat4: adds "Time" (and WavePacket?)
>> ePointFormat5: adds ???
> ePointFormat5: adds "Time" and Color and WavePacket
>> Besides clarifying those options a bit more for the documentation,
>> could someone tell if this means we cannot define our own schema?
> We cannot. LAS has those 6 point types. If you only use XYZ and RGB
> then you should use point type 2. If you are worried about space (e.g.
> storing too many unused fields) you can consider leaving all those
> fields at zero and storing your data LASzip compressed ... they will
> be pretty much "compressed away" completely.
I would say this is not entirely descriptive.  It is legal LAS to have all of the fields of the "fixed" portion of the point format *plus* any extra bytes beyond the base point format that can contain whatever you want.  libLAS liblas::Schema attempts to model this by allowing you to initialize it via a point format (ePointFormat1, ePointFormat3, etc) and then go add any liblas::Dimension items you wish to describe anything else you want (they must be aligned to a single byte, but sub-byte-sized dimensions are allowed if they pack to byte boundaries -- this is how a number of dimensions in the base point formats are modeled).  After that, you set the header's data format id to your point format, and then the data record length to the complete size
This work is not yet complete in libLAS 1.6.0, however.  The code that describes custom schemas (those that have dimensions beyond the base point format-required ones) is done, as is some XML description of these schemas that can be put into a VLR to support interpretation of the extended data, but the code that actually reads and writes the extend data in liblas::Reader and liblas::Writer is not done.  This
More information about the Liblas-devel mailing list
