[Liblas-devel] txt2las with .zip
Martin Isenburg martin.isenburg at gmail.com
Thu Mar 17 12:20:45 EDT 2011
hallo list,
sarah and i have figured out how to do it. download these unzip.exe
and txt2las.exe
http://stahlworks.com/dev/unzip.exe
http://www.cs.unc.edu/~isenburg/lastools/download/txt2las.exe
and put them into the same folder. then run
unzip -pM  pt000374.zip | txt2las -itxt -o pt000374.laz -parse txyzar
which works on my machine as well as on sarah's. the example
pt000374.zip file is available on request.
cheers,
martin
On Thu, Mar 17, 2011 at 7:15 AM, Sarah Schuessler <sarah_flip at yahoo.de> wrote:
> Hi list,
> I hope I´m right here at this mailing list. If not let me know.
> My problem is:
> I have  a lot of .zip files and want to create .laz files out of them. I
> read at liblas.org that there is a command
> txt2las -parse txyzar lidar.txt.gz lidar.laz
> I modified this to my needs:
> txt2las -parse xyz xxx.zip xxx.laz
> but that didn`t work.
> Tried with different changes but nothing worked.
> I do gzip, txt2las and then laszip but it would be nice if txt2las could do
> it with one step.
> If this is not possible can anyone perhaps tell me if it is possible to
> override my uncompressed zip-file?
> Or is it normal behavior that I`m having one for example .txt file and then
> one .las file?
> Thank you for any comments!
> best regards
> S.
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
