[Liblas-devel] txt2las with .zip
Martin Isenburg martin.isenburg at gmail.com
Thu Mar 17 14:21:38 EDT 2011
hello once more,
sarah's question got motivated to add unzipping via a pipe to txt2las.
so now it's either
txt2las -i pt000374.txyzar.gz -o pt000374.laz -parse txyzar
or
txt2las -i pt000374.zip -o pt000374.laz -parse txyzar
with the latest version of txt2las.exe (*). note that you will still
need to have gzip.exe and/or unzip.exe in the path.
cheers,
martin
(*) http://www.cs.unc.edu/~isenburg/lastools/download/txt2las.exe
On Thu, Mar 17, 2011 at 9:20 AM, Martin Isenburg
<martin.isenburg at gmail.com> wrote:
> hallo list,
> sarah and i have figured out how to do it. download these unzip.exe
> and txt2las.exe
> http://stahlworks.com/dev/unzip.exe
> and put them into the same folder. then run
> unzip -pM  pt000374.zip | txt2las -itxt -o pt000374.laz -parse txyzar
> which works on my machine as well as on sarah's. the example
> pt000374.zip file is available on request.
> cheers,
> martin
> On Thu, Mar 17, 2011 at 7:15 AM, Sarah Schuessler <sarah_flip at yahoo.de> wrote:
>> Hi list,
>> I hope I´m right here at this mailing list. If not let me know.
>> My problem is:
>> I have  a lot of .zip files and want to create .laz files out of them. I
>> read at liblas.org that there is a command
>> txt2las -parse txyzar lidar.txt.gz lidar.laz
>> I modified this to my needs:
>> txt2las -parse xyz xxx.zip xxx.laz
>> but that didn`t work.
>> Tried with different changes but nothing worked.
>> I do gzip, txt2las and then laszip but it would be nice if txt2las could do
>> it with one step.
>> If this is not possible can anyone perhaps tell me if it is possible to
>> override my uncompressed zip-file?
>> Or is it normal behavior that I`m having one for example .txt file and then
>> one .las file?
>> Thank you for any comments!
>> best regards
>> S.
>> Liblas-devel mailing list
>> Liblas-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
