[Liblas-devel] liblas 1.6.1, laszip 1.0 dependency
Martin Isenburg martin.isenburg at gmail.com
Sat Oct 29 07:34:31 EDT 2011
good point. is there no stable liblas release with laszip 2.0 support,
howard? in this case we should have a tarball of the previous versions on
the site? but i do not recommend using laszip 1.x since you loose the random
access / spatial indexability of your LAZ files.
martin
On Fri, Oct 28, 2011 at 2:35 PM, Charles Cowart <charliec at sdsc.edu> wrote:
> Hello,
> It appears to me that liblas 1.6.1 depends specifically on 1.x laszip to
> compile with laszip support; my attempts to compile with laszip 2.0 yield
> errors with what appear to be modified/replaced data structures, etc. It
> also appears that Martin is no longer offering laszip 1.x from the laszip
> site. Given that 1.6.1 is the current stable release, I felt this might be
> an issue to bring to the community's attention.
> Charles Cowart
> www.opentopography.org_______________________________________________
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20111029/764872b3/attachment.html
More information about the Liblas-devel mailing list
