[Liblas-devel] ARSF LiDAR Analysis GUI
Howard Butler hobu.inc at gmail.com
Thu Aug 23 07:54:03 PDT 2012
This looks awesome.
I'll add that Grant Brown added a freeglut-based simple viewer (lasviewer) based on PyOpenGL to laspy at https://github.com/grantbrown/laspy .  It needs quite a bit of work (addition of mouse navigation would be nice), but the fun part is that it's programmable in pure python. It's primary features are fly-through navigation and RGB/Intensity colorization.  PDAL has a freeglut-based simple viewer too, but both of these are simple visualization -- and they're not as useful as LAG appears to be.
Martin,
When can we convince you that proper source code tracking and versioned releases are prerequisite for people to build upon your software?  It's great that LASlib is LGPL, but it's frustrating that we can't refer to release versions, or track your changes in a revision system unless we're doing it ourselves manually.  Things like LAG demonstrate the need for this even more clearly.
Howard
On Aug 23, 2012, at 9:25 AM, Berin Smaldon wrote:
> Hi again,
> I was disappointed to find that the previous developer had just added a function to check the filename ending for ".las" or ".LAS" to decide whether a given file is a LAS file or not. I have added .laz and .LAZ for the time being, and merged the changes into the testing branch, where LAG now appears to load LAZ files without a single hiccup.
> I should hope to change this in future.
> For the meantime, anyone who wants this functionality can use git to use the hotfix:
> git clone git at github.com:arsf/lag.git
> git checkout testing
> *compile as usual*
> Berin
> On 23/08/12 15:08, Martin Isenburg wrote:
>> Hi Berin,
>> if you use LASlib and you can open LAS files then you can also open LAZ files as the code path is the same. It may be that your LAG file selector does not allow a *.laz ending? In this case simply test by renaming (temporarily) a *.laz file to *.las and try to open it. LASlib decides based in the content (not the ending) whether the LAS file is compressed of not.
>> Cheers,
>> Martin
>> PS: if you use lasreadopener, then you would also BIN/SHP/QFIT/ASCII/ASC/BIL support that would get opened "as if" they were LAS files ...
> Plymouth Marine Laboratory
> Registered Office:
> Prospect Place
> The Hoe
> Plymouth  PL1 3DH
> Website: www.pml.ac.uk
> Click here for the latest PML Annual Review
> Registered Charity No. 1091222
> PML is a company limited by guarantee
> registered in England & Wales
> company number 4178503
> Please think before you print.
> This e-mail, its content and any file attachments are confidential.
> If you have received this e-mail in error please do not copy, disclose it to any third party or use the contents or attachments in any way. Please notify the sender by replying to this e-mail or e-mail forinfo at pml.ac.uk and then delete the email without making any copies or using it in any other way.
> The content of this message may contain personal views which are not the views of Plymouth Marine Laboratory unless specifically stated.
> You are reminded that e-mail communications are not secure and may contain viruses. Plymouth Marine Laboratory accepts no liability for any loss or damage which may be caused by viruses.
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20120823/ea193199/attachment.html>
More information about the Liblas-devel mailing list
