[Liblas-devel] Can Liblas only update a small portion of the points in Lidar file?
Howard Butler hobu.inc at gmail.com
Fri Feb 10 11:49:41 EST 2012
On Feb 8, 2012, at 12:41 PM, Hongwei Shen wrote:
> To solve this problem, I  think we can add a member variable, m_AbsoluteIndex, to liblas::Point.  Then we can also store the absolute index of the point in liblas::detail::ReadNextPoint() .
I think I'm ok with this as long as the tests continue to pass.
> To implement a ReaderUpdater (or ReaderWriter),  I think we can do the following:
> 1.
> Add ReaderUpdaterI  in liblas.hpp:
> 2.
> Add a class, liblas:detail:ReaderUpdater
> 3.
> Of course,  add class liblas::ReaderUpdater  to wrap liblas::detail::ReaderUpdater
> How do you think of these changes?  Will they break current design and/or other software that use liblas?
This looks ok to me as well.
Please implement this in your github fork and send the libLAS tree a pull request when you are complete.  I'll pull it down and make sure everything continues to pass and we'll push it out in a new release.
Thanks for the effort!
Howard
More information about the Liblas-devel mailing list
