[Liblas-devel] Can Liblas only update a small portion of the points in Lidar file?
Howard Butler hobu.inc at gmail.com
Fri Feb 10 12:15:21 EST 2012
On Feb 10, 2012, at 11:10 AM, Martin Isenburg wrote:
> Hi,
> Make sure you disable the feature when the file is laszipped. There is
> *no* way to add this. However, we could - in theory - support the
> appending of points to an exsiting LAZ file.
Yes, definitely.  The "Update" class will not be able to have LASzip-based data underneath it.
Howard
More information about the Liblas-devel mailing list
