[Liblas-devel] Re: GetProj4() string and NAD83
Howard Butler hobu.inc at gmail.com
Tue Jan 10 12:01:59 EST 2012
On Jan 10, 2012, at 10:30 AM, Howard Butler wrote:
> I'll try to dig into this some more...
GDAL isn't turning this into a proper proj.4 string.
>      GTModelTypeGeoKey (Short,1): ModelTypeProjected
>       GTCitationGeoKey (Ascii,14): "UTM zone 15N"
>       GeogGeodeticDatumGeoKey (Short,1): Datum_North_American_Datum_1983
>       GeogEllipsoidGeoKey (Short,1): Ellipse_GRS_1980
>       ProjectedCSTypeGeoKey (Short,1): PCS_NAD83_UTM_zone_15N
>       ProjCoordTransGeoKey (Short,1): CT_TransverseMercator
>       ProjLinearUnitsGeoKey (Short,1): Linear_Meter
>       VerticalCSTypeGeoKey (Short,1): VertCS_North_American_Vertical_Datum_1988
>       VerticalCitationGeoKey (Ascii,19): "GEOID 2003 Applied"
>       VerticalUnitsGeoKey (Short,1): Linear_Meter
is coming out of GDAL as:
> +proj=tmerc +lat_0=0 +lon_0=0 +k=1 +x_0=0 +y_0=0 +datum=NAD83 +units=m +geoidgrids=g2003conus.gtx,g2003alaska.gtx,g2003h01.gtx,g2003p01.gtx +vunits=m +no_defs
note the parameters, they're all 0.
I don't know whether or not this is a bad set (or incompletely specified) of GeoTIFF keys, or whether or not GDAL should be taking the ProjectedCSTypeGeoKey straight off, as this defines the coordinate system parameters fully via lookup.  Frank, are you still around?
Howard
More information about the Liblas-devel mailing list
