[Liblas-devel] VS2010 LNK2005 error between msvcprtd.lib and libboost
Werner Goeman wgoeman at telin.ugent.be
Wed Mar 28 07:49:36 EDT 2012
Setup: VS2010 – Cmake 2.8.7 – libLAS1.7.0
This is about a LNK2005 error between msvcprtd.lib and
libboost_program_options-vc100-mt-sgd-1_47.lib
I follow the documentation as close as possible. I didn’t add optional
libraries, only boost was installed (succesfully). CMake runs good, I
think, but selects the static lib which are mutlithread NOT debug mode.
I fixed this by manually changing the libs in CMake GUI. The solution
for VS was then created.
When I try to build in VS2010, I get the same type of error all over:
File msvcprtd.lib(MSVCP100D.dll):
error LNK2005: "public: struct std::_Iterator_base12 * * __thiscall
std::_Container_base12::_Getpfirst(void)const "
(?_Getpfirst at _Container_base12@std@@QBEPAPAU_Iterator_base12 at 2@XZ)
already defined in
libboost_program_options-vc100-mt-sgd-1_47.lib(parsers.obj)
C:\Dev\libLAS\libLAS-1.7.0\src\msvcprtd.lib(MSVCP100D.dll)
It looks to me that I need to link against the dynamic libraries of
boost, but when I try that, VS always tries to find the wrong libs even
after I manually changed the filenames to link against in CMake and/or
the project settings itself in VS. The thing there is that the cmake
construct expects the library names to begin with “libboost” which is
the case for static libs, but for dynamic ones it is just “boost”. When
trying to build, it seems that the libboost files are still linked
against even if they are NOT mentioned in the project settings. But in
the end, I don’t know if that willl solve my LNK2005 problem above…
Can someone give a clue what is happening here?
Thank you!
Werner
More information about the Liblas-devel mailing list
