[Liblas-devel] Patches to cmake configuration for libLAS 1.7.0
Charles Karney charles.karney at sri.com
Fri Oct 5 07:20:39 PDT 2012
I have made some patches to the cmake configuration for libLAS 1.7.0
(roughly in order of importance):
(1) Add support for find_package(libLAS). Installation adds a file
liblas-config.cmake to the installation tree and find_package will use
this to determine the include directories and library paths.
(2) Fix FindGeoTIFF.cmake so that it works for Linux (PATH_PREFIXES
should be PATH_SUFFIXES and libgeotiff needs to be searched as well as
geotiff).
(3) Remove -pedantic compilation option for Unix because it causes
compilation to fail with boost 1.15.0 under Linux (because of a comma at
the end of an enum list).
(4) Add runtime library path to libLAS utilities for Unix.
(5) Remove -Wcast-qual, -Wfloat-equal, and -Wredundant-decls compilation
options for Unix to reduce the number of compilation warnings.
I posted this as an "issue" on github a month ago; but there is no
provision for attaching the patch.  So I'm including the patch in this
E-mail.  (Be warned that the patch may not apply cleanly because the
release is inconsistent in its use of DOS vs Unix line endings.)
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 21461a5..954619d 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -139,8 +139,12 @@ else()
    # Recommended C++ compilation flags
    # -Weffc++
+  # Remove -pedandic which causes errors from boost (comma at end of
+  # enum) 2012-09-05.  Remove -Wcast-qual -Wfloat-equal
+  # -Wredundant-decls to suppress the multitude of warning messages.
    set(LIBLAS_COMMON_CXX_FLAGS
-	"-pedantic -ansi -Wall -Wpointer-arith -Wcast-align -Wcast-qual
-Wfloat-equal -Wredundant-decls -Wno-long-long")
+	"-ansi -Wall -Wpointer-arith -Wcast-align -Wno-long-long")
    if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
@@ -354,7 +358,8 @@ else()
    endif()
  endif()
+# Add find_package(libLAS) support
+add_subdirectory(cmake)
  # Version information
  SET(CPACK_PACKAGE_VERSION_MAJOR ${LIBLAS_VERSION_MAJOR})
diff --git a/apps/CMakeLists.txt b/apps/CMakeLists.txt
index 7dc71c3..1b30cdd 100644
--- a/apps/CMakeLists.txt
+++ b/apps/CMakeLists.txt
@@ -180,6 +180,22 @@ install(TARGETS ${LIBLAS_UTILITIES}
  if(UNIX)
+  set(LIBLAS_UTILS_RPATH ${CMAKE_INSTALL_PREFIX}/lib ${Boost_LIBRARY_DIRS})
+  if(LASZIP_FOUND)
+    get_filename_component(LASZIP_LIBRARY_DIRS ${LASZIP_LIBRARY} PATH)
+    set (LIBLAS_UTILS_RPATH ${LIBLAS_UTILS_RPATH} ${LASZIP_LIBRARY_DIRS})
+  endif()
+  if(GEOTIFF_FOUND)
+    get_filename_component(GEOTIFF_LIBRARY_DIRS ${GEOTIFF_LIBRARY} PATH)
+    set (LIBLAS_UTILS_RPATH ${LIBLAS_UTILS_RPATH} ${GEOTIFF_LIBRARY_DIRS})
+  endif()
+  if(GDAL_FOUND)
+    get_filename_component(GDAL_LIBRARY_DIRS ${GDAL_LIBRARY} PATH)
+    set (LIBLAS_UTILS_RPATH ${LIBLAS_UTILS_RPATH} ${GDAL_LIBRARY_DIRS})
+  endif()
+  set_target_properties(${LIBLAS_UTILITIES} PROPERTIES
+    INSTALL_RPATH "${LIBLAS_UTILS_RPATH}")
    if(WITH_PKGCONFIG)
      set(PKGCFG_PREFIX "${CMAKE_INSTALL_PREFIX}")
diff --git a/cmake/CMakeLists.txt b/cmake/CMakeLists.txt
new file mode 100644
index 0000000..18c876a
--- /dev/null
+++ b/cmake/CMakeLists.txt
@@ -0,0 +1,33 @@
+# Config file generation and installation
+# Set where cmake will install liblas-config.cmake.  It's installed in
+# ${CMAKE_INSTALL_PREFIX}/${INSTALL_CMAKE_DIR} and ${PROJECT_ROOT_DIR}
+# is the relative path to the root from there.
+if (NOT WIN32)
+  set(INSTALL_CMAKE_DIR "share/cmake/${PROJECT_NAME}-${VERSION}")
+  set (PROJECT_ROOT_DIR "../../..")
+else ()
+  set(INSTALL_CMAKE_DIR "cmake")
+  set (PROJECT_ROOT_DIR "..")
+endif ()
+# Now create the liblas-config files using the .in templates
+configure_file (liblas-config.cmake.in
+  ${CMAKE_CURRENT_BINARY_DIR}/liblas-config.cmake @ONLY)
+configure_file (liblas-config-version.cmake.in
+  ${CMAKE_CURRENT_BINARY_DIR}/liblas-config-version.cmake @ONLY)
+# Install the liblas-config files so that other modules can find this
+# project using 'find_package(libLAS)'
+install (FILES
+  "${CMAKE_CURRENT_BINARY_DIR}/liblas-config.cmake"
+  "${CMAKE_CURRENT_BINARY_DIR}/liblas-config-version.cmake"
+  DESTINATION "${INSTALL_CMAKE_DIR}")
+# Make information about libLAS available.  The depends target is
+# defined in ../src/CMakeLists.txt
+install (EXPORT depends
+  FILE "liblas-depends.cmake"
diff --git a/cmake/liblas-config-version.cmake.in
b/cmake/liblas-config-version.cmake.in
index 0000000..7ad76d6
--- /dev/null
+++ b/cmake/liblas-config-version.cmake.in
@@ -0,0 +1,18 @@
+# Version checking for libLAS
+set(PACKAGE_VERSION "@VERSION@")
+set(PACKAGE_VERSION_MAJOR "@LIBLAS_VERSION_MAJOR@")
+set(PACKAGE_VERSION_MINOR "@LIBLAS_VERSION_MINOR@")
+set(PACKAGE_VERSION_PATCH "@LIBLAS_VERSION_PATCH@")
+if (WIN32 AND NOT "${CMAKE_GENERATOR}" STREQUAL "@CMAKE_GENERATOR@")
+  # Reject if there's a mismatch on compiler versions (Windows only)
+  set (PACKAGE_VERSION_UNSUITABLE TRUE)
+elseif (PACKAGE_FIND_VERSION)
+  if (${PACKAGE_FIND_VERSION} VERSION_EQUAL ${PACKAGE_VERSION})
+    set (PACKAGE_VERSION_EXACT TRUE)
+  elseif (${PACKAGE_FIND_VERSION} VERSION_LESS ${PACKAGE_VERSION}
+    AND ${PACKAGE_FIND_VERSION_MAJOR} EQUAL ${PACKAGE_VERSION_MAJOR})
+    set (PACKAGE_VERSION_COMPATIBLE TRUE)
+  endif ()
+endif ()
diff --git a/cmake/liblas-config.cmake.in b/cmake/liblas-config.cmake.in
index 0000000..51e1163
--- /dev/null
+++ b/cmake/liblas-config.cmake.in
@@ -0,0 +1,29 @@
+# Configure libLAS package
+# It defines the following variables
+#  libLAS_FOUND = LIBLAS_FOUND - TRUE
+#  libLAS_INCLUDE_DIRS - include directories for libLAS
+#  libLAS_LIBRARY_DIRS - library directory
+#  libLAS_LIBRARIES    - all the libraries of the components requested
+#                                if no components specified then all found
+#  libLAS_VERSION      - libLAS library version
+message (STATUS "Reading ${CMAKE_CURRENT_LIST_FILE}")
+set (libLAS_VERSION "@PACKAGE_VERSION@")
+message (STATUS "libLAS configuration, version "
+  ${libLAS_VERSION})
+# Tell the user project where to find our headers and libraries
+get_filename_component (_DIR ${CMAKE_CURRENT_LIST_FILE} PATH)
+get_filename_component (PROJECT_ROOT_DIR "${_DIR}/@PROJECT_ROOT_DIR@"
ABSOLUTE)
+set (libLAS_INCLUDE_DIRS "${PROJECT_ROOT_DIR}/include")
+set (libLAS_LIBRARY_DIRS "${PROJECT_ROOT_DIR}/lib")
+include ("${_DIR}/liblas-depends.cmake")
+if(WIN32)
+  set (libLAS_LIBRARIES liblas liblas_c)
+else()
+  set (libLAS_LIBRARIES las las_c)
+endif()
+set (LIBLAS_FOUND TRUE)
diff --git a/cmake/modules/FindGeoTIFF.cmake
b/cmake/modules/FindGeoTIFF.cmake
index e0bcd45..28d498f 100644
--- a/cmake/modules/FindGeoTIFF.cmake
+++ b/cmake/modules/FindGeoTIFF.cmake
@@ -38,7 +38,7 @@ ENDIF()
  FIND_PATH(GEOTIFF_INCLUDE_DIR
    geotiff.h
-  PATH_PREFIXES geotiff
+  PATH_SUFFIXES geotiff libgeotiff
    PATHS
    ${OSGEO4W_ROOT_DIR}/include)
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index d378358..212e1a4 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -254,9 +254,12 @@ if (APPLE)
  endif()
-# Targets installation
+# Targets installation.  The EXPORT clause specifies a depends target
+# which packages up information about the libraries for
+# liblas-config.cmake.
  install(TARGETS ${LIBLAS_LIB_NAME} ${LIBLAS_C_LIB_NAME}
+  EXPORT depends
    RUNTIME DESTINATION ${LIBLAS_BIN_DIR}
    LIBRARY DESTINATION ${LIBLAS_LIB_DIR}
    ARCHIVE DESTINATION ${LIBLAS_LIB_DIR})
Charles Karney <charles.karney at sri.com>
SRI International, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
Fax: +1 609 734 2662
More information about the Liblas-devel mailing list
