[Liblas-devel] Preparing for 1.8.2
Mateusz Loskot mateusz at loskot.net
Mon May 25 12:58:39 PDT 2020
Peder,
I've got to put liblas releasing along with all my side projects on back
burner due to limited time due to work interleaving with parenting duties
due to nurseries closure due to COVID19.
I'll pick it up again as soon as possible, but no idea when that'll happen.
Mateusz Loskot, mateusz at loskot.net
(Sent from mobile, may suffer from top-posting)
p.s. I recommend posting to liblas-devel at lists.osgeo.org as I don't promise
any private communication about any open source projects I maintain.
On Mon, 25 May 2020, 14:56 Peder Axensten, <Peder.Axensten at slu.se> wrote:
> Hello again, Mateusz,
> If you are still working on an update to liblas, you might consider
> removing the following warning:
> In file included from /usr/local/include/liblas/detail/binary.hpp:28:
> In file included from /opt/local/include/boost/detail/endian.hpp:9:
> /opt/local/include/boost/predef/detail/endian_compat.h:11:9: warning: The
> use of BOOST_*_ENDIAN and BOOST_BYTE_ORDER is deprecated. Please include
>       <boost/predef/other/endian.h> and use BOOST_ENDIAN_*_BYTE instead
> [-W#pragma-messages]
> #pragma message("The use of BOOST_*_ENDIAN and BOOST_BYTE_ORDER is
> deprecated. Please include <boost/predef/other/endian.h> and use
> BOOST_ENDIAN_*_BYTE instead")
> Best regards,
> Peder Axensten
> Research engineer
> Remote Sensing
> Department of Forest Resource Management
> Swedish University of Agricultural Sciences
> SE-901 83 Umeå
> Visiting address: Skogsmarksgränd
> Phone: +46 90 786 85 00
> peder.axensten at slu.se, www.slu.se/srh
> The Department of Forest Resource Management is environmentally certified
> in accordance with ISO 14001.
> > On 4 May 2020, at 17:19, Mateusz Loskot <mateusz at loskot.net> wrote:
> > Hi,
> > I am trying to prepare for releasing libLAS 1.8.2 (bugfix release).
> > I started collecting release notes:
> > https://github.com/libLAS/libLAS/blob/master/RELEASE_NOTES.md
> > The major task ahead is to run the docs update, if it takes too long,
> > I may decide to publish the release with minimal update only.
> > Any help would be appreciated.
> > Best regards,
> > Mateusz Loskot, http://mateusz.loskot.net
> > Liblas-devel mailing list
> > Liblas-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/liblas-devel
> När du skickar e-post till SLU så innebär detta att SLU behandlar dina
> personuppgifter. För att läsa mer om hur detta går till, klicka här <
> https://www.slu.se/om-slu/kontakta-slu/personuppgifter/>
> E-mailing SLU will result in SLU processing your personal data. For more
> information on how this is done, click here <
> https://www.slu.se/en/about-slu/contact-slu/personal-data/>
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20200525/9309db6b/attachment.html>
More information about the Liblas-devel mailing list
