[rttopo-dev] Tolerance 0 support in master branch
Andrea Peri aperi2007 at gmail.com
Tue Sep 6 06:55:50 PDT 2016
I search in
https://git.osgeo.org/gogs/rttopo/librttopo
but not find any folder "test"
wrong site ?
2016-09-06 15:21 GMT+02:00  <a.furieri at lqt.it>:
> On Tue, 6 Sep 2016 13:42:48 +0200, Andrea Peri wrote:
>> (sorry my email was hard to understand due tomy poor english, and to
>> smartphone)
>> So try to resend with some adjust:
>> Hi Alessandro.
>> You are reason.
>> But dont forget that rt-topology is an youger libraries and do some
>> change (without support previous version) to allow a robustness
>> beaviour now is reasonable.
>> Tolerance 0 is most clear associable to a no one kind of rounding
>> rather than to a dinamic tolerance (as is now).
>> I guess is no too heavy a change applied to test-suite moving from 0
>> to -1 actual settings.
>> Could do it myself ?
> Hi Andrea,
> you are right; manually patching the current testcases so to
> correctly support the most recent librttopo changes shouldn't
> be difficult at all.
> it should require just few trivial changes in both
> -/test/check_topology2d.c  and -/test/check_topology3d.c
> sources
> bye Sandro
Andrea Peri
qwerty àèìòù
More information about the librttopo-dev mailing list
