[rttopo-dev] rtt_AddLineNoFace available in master branch
aperi2007 aperi2007 at gmail.com
Thu Sep 8 10:30:35 PDT 2016
I remenber the minus sign in topology identify the way of rotation in edges.
Don't remenber if has some se in face identify.
Perhaps better NULL values ?
Il 08/09/2016 19:26, Sandro Santilli ha scritto:
> I've made available a new function: rtt_AddLineNoFace.
> The function allows adding an arbitrary line to an existing
> topology, noding it as appropriate with existing linework,
> but NOT checking for new faces being generated.
> It's been tested for incremental lines addition starting
> from an empty topology and it works fine. The datastore
> is passed edge records with left_face/right_face valued -1
> to signify "unknown".
> Tests welcome.
> --strk;
> librttopo-dev mailing list
> librttopo-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/librttopo-dev
More information about the librttopo-dev mailing list
