[Live-demo] Mapnik
Dane Springmeyer blake at hailmail.net
Sun Aug 30 15:24:17 EDT 2009
Install script attached (and pasted below) which installs Mapnik 0.5.1
(available via packages on 9.04) and a simple 'Hello World' OpenLayers
demo application.
Cheers,
Dane
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/live-demo/attachments/20090830/ded32f34/install_mapnik.obj
#!/bin/sh
# Copyright (c) 2009 The Open Source Geospatial Foundation.
# Licensed under the GNU LGPL.
# About:
# This script will install Mapnik library and Python bindings
# and TileLite for a demo 'World Borders' application
# Running:
# sudo ./install_mapnik.sh
# will fetch Mapnik 0.5.1 on Ubuntu 9.04
apt-get install python-mapnik
# download, install, and setup demo Mapnik tile-serving application
TMP="/tmp/tilelite"
DATA_FOLDER="/usr/local/share"
mkdir $TMP
cd $TMP
# download TileLite sources
wget http://bitbucket.org/springmeyer/tilelite/get/tip.zip
unzip tip.zip
cd tilelite
# using the standard python installation tools
python setup.py install # will install 'tilelite.py' in site-packages
and 'liteserv.py' in default bin directory
# copy TileLite demo application and data to 'mapnik' subfolder of
DATA_FOLDER
mkdir $DATA_FOLDER/mapnik
cp demo $DATA_FOLDER/mapnik -R
# then to run demo do...
cd $DATA_FOLDER/mapnik
# lauch the tile server with a Mapnik XML mapfile as input
liteserv.py demo/population.xml
# Note on the above command which launchs server.
# The paths in XML mapfile depend on the demo being run from this
exact spot,
# so users must either edit the shapefile path inside 'population.xml'
or make sure to
# run from '$DATA_FOLDER/mapnik'
## MANUAL STEPS ##
# View the server homepage:
# open in a browser...
# http://yourdomain.com:8000 or http://localhost:8000
# Then view the tiles in sample OpenLayers Map (needs internet
connection for OpenLayers.js, etc)
# file:///usr/local/share/mapnik/demo/openlayers.html
More information about the Live-demo mailing list
