[Live-demo] 2.0.3 testing
Jody Garnett jody.garnett at gmail.com
Thu Oct 1 00:39:06 EDT 2009
Yep; It is on its way to be printed as we speak.
Great work everyone - I now have to get back to my day job.
Jody
On Thu, Oct 1, 2009 at 1:30 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> Jody Garnett wrote:
>> Quick:
>> - Number one advice - turn off networking before trying out the web
>> applications.
>> - This is very cool - I am going to use it to run my "friendly
>> introduction" tutorial :-)
>> Running log of test activities - I will test as much as I can before it
>> goes out the door.
>> udig starts up
>> - data directory short cut works
>> geoserver start does not work smoothly; firefox is opened before server
>> is available; turning
>> -- workaround - turn off networking & close firefox and click on the
>> Admin GeoServer link
>> - geoserver wms works
>> -- png8 not transparent background for tasmania dataset; changing to png
>> as workaround
>> - geoserver wfs works
>> - geoserver wfs-t works
>> - stop geoserver worked
>> deegree starts up
>> - same problem as geoserver; firefox is there before the server can respond
>> - deegree wms works
>> -- layer metadata not correct (all the Utah datasets default to world
>> extend making it hard to find them when opening an empty map - ie zoom
>> to layer does not work if layer bounds not provided in capabilities
>> document)
>> -- getting some very fun visual gltiches due to deegree watermarking -
>> ie when ortho image shown the watermark will appear once for the bounds
>> of the other layers; and once for the smaller size of the orth images
>> - deegree wfs capabilities document produced; udig is unable to handle
>> the actual GML produced
>> -- wfs layers do not provide title (resulting in only "Spring in Utah"
>> being visible; rendering with 1.1.0 failed with "unknown respond result
>> for GetFeature - unrecognized server error WFS_1_1_0_DataStore.java 334
>> -- a bit better with 1.0.0 - basically this stuff fails when parsing the
>> describe feature type response NPE in WFS_1_0_DataStore 306
>> - stop deegree worked
>> pgAdmin
>> - crashed when I trying to view contents of Sydney database; asked me to
>> report problem etc...
>> - restarted ran "SELECT * FROM sydney" without problem
>> - uDig connected fine and was able to run through the roads without
>> problem, and display results in table view; was unable to figure out
>> correct bounds for data but that is probably udig's problem
>> mapsever
>> - demo Itasca works
>> - wms capabilities document not provided as a link anywhere I could find
>> - gmap demo very pretty
>> -- click to enable java mode does not work
>> qgis
>> - works displays countries and clouds.jpg; symbolic link in home
>> directory helped here
>> open jump
>> kosmo
>> I am out of time and cannot test any more prior to this going out. If
>> anyone is available Monday we are going to try and round up volunteers
>> to place the dvd into the conference bags etc...
>> Jody
> I take it that means we should post the 2.0.3 image to the download
> server now?
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo mailing list
