[Live-demo] 2.0.3 testing
Cameron Shorter cameron.shorter at lisasoft.com
Thu Oct 1 16:02:32 EDT 2009
Hamish, I think this is a good idea, in particular being able to create
a freeze of a build scripts so that it can be reproduced later.
I suggest going one step further.
Our build process starts by downloading everything from
livedvd/gisvm/trunk/ and get we use wget to get files out of svn during
the build process.
What I suggest is that we:
1. Instead of sourcing files by "wget -c
http://svn.osgeo.org/livedvd/gisvm/trunk/dir/file" we should source the
file from the version we have already downloaded which is currently at:
"~/gisvm/trunk/bin/../dir/file".  We can rename the gisvm svn directory
so that it is one below trunk, which will make scripts easier to run.
I suggest that we start making use of the tags directory. So that I can
check out the 2.0.3. At times it is important to distinguish between
2.0.3 and 2.0.4 if there are users for both version. This is more
important than using the branch directory. In fact, I suspect that we
will avoid the need to use the branch directory for the most part,
unless we decide to create an "unstable" build list and a "stable" build
list.
2. I suggest that we store a copy of the /tmp download directory. Some
projects are likely to move their download source location, and if they
do, then it will be hard for us to reproduce an old release.
Hamish wrote:
>> I should probably go through the commit log and give you a
>> list of what I actually applied, since a lot of changes from
>> 2.0 were done by hand.
> I've been trying to do that already, syncing by hand stuff which
> seemed relevant from trunk about once per day. I don't claim 100%
> accuracy but was focusing on scripted solutions to stuff which
> you did by hand in the VM. As such I'm not too concerned about
> any noise which snuck in, but I would be curious to know which
> things have been done by hand in the VM which have not had a
> scripted solution checked in since. (to add a README.adjustments)
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
