[Live-demo] Version numbers
Cameron Shorter cameron.shorter at lisasoft.com
Thu Oct 1 18:06:34 EDT 2009
Alex, minor suggestions re naming convention, (I've been following what
I believe to be close to ubuntu conventions)
* Only use lower case.
Use:
arramagong-livedvd-2.0.3 (note no "Final" in the name)
In retrospect, I suspect we should have:
arramagong-2.0.3-livedvd.iso rather than arramagong-livedvd-2.0.3.iso
Richardo,
For the virtual machine, we have been adding "gisvm" into the tag.
Ie: arramagong-gisvm-2.0.3
Do you want gisvm to be specifically associated like the above, or do
you want to create a separate gisvm which is different from arramagong?
Eg: We could have:
arramgong-vm-2.0.3
and
gisvm-2.0.3.1 or similar.
What are your thoughts.
Alex Mandel wrote:
> For those who have access to the download server edit the index.html,
> please keep in mind that file is in svn, so it's best if you make
> changes on your machine, commit them and then svn up on the osgeo
> server. Otherwise edits may be lost, clobbered or otherwised mixed up.
> FYI, 2.0.3-Final links are now active.
> No torrent till we resolve best approach. VM's sometime over the weekend.
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
