[Live-demo] Does your application work on the click2try GISVM?
Aneel aneel.r at tecnics.com
Tue Oct 13 05:59:56 EDT 2009
On Tue, 2009-10-13 at 07:42 +1100, Cameron Shorter wrote:
> Aneel wrote:
> > Hello Cameron and Osgeo team,
> > After screening all the mails till now , we have listed out the issues
> > mentioned by osgeo members.
> > Some of the issues we have already fixed in multilayer gisvm. They are
> > 1. There are no icons for deegree
> > 2. There is no mapserver icon
> > 3. The "Start Mapnik & TileLite" icon is missing
> > 4. There is no "MapTiler" icon
> > 5. #494: Remove screen saver on click2try image
> > 6. #495: click2try VM user/password should be same as LiveDVD
> > Pending issues to be fixed and we are trying to fix it. If you have
> > any information please let us know
> > 1. GeoNetwork - it doesn't work
> > 2. The desktop icon using launchassist.sh is rigged specifically to the
> > password user on the sudo command. That's probably why it didn't work.
> I believe these 2 issues are related.
> Now that you have changed user/password to user/user, I suggest
> re-running the install_geonetwork.sh script:
>   sudo ./install_geonetwork.sh 2>&1 | tee /var/log/arramagong/install_geonetwork.log
I have re-executed the  install_geonetwork.sh script as cameron
suggested but still issue persists. I have resolved this by adding
"user" in admin group & given sudoer privileges to admin group.
> > Developers who are re-testing, can do modification as they want on
> > click2try image (Vm) and please let us know the changes to fix them
> > permanently.
> > How to access gisvm:
> > URL http://www.click2try.com
> > user id  : osgeo
> > password : livedemo
> > Once logged in, navigate to My Dashboard -> Applications Manager.  You will see
> > a VM named osgeo-gisvm20-2.  Hilite that and click the red LAUNCH button. This will connect you to the VM
> > Gnome Desktop user credentials:
> > user id      : user
> > password : user
> > One another point, this running vm is build using
> > "branches/arramagong_2" and please find below errors (got while
> > Installation)
> > Error1:
> > cp: omitting directory `/usr/local/share/grass/spearfish60/user1/dbf'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cats'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cell'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cell_misc'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cellhd'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/colr'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/colr2'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/dbf'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/fcell'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/g3dcell'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/hist'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/vector'
> > cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/windows'
> > Adding user `user' to group `users' ...
> > Adding user user to group users
> > Done.
> > 2009-10-09 17:22:41
> > URL:http://svn.osgeo.org/grass/grass/trunk/gui/icons/grass-48x48.png
> > [2407/2407] -> "grass-48x48.png" [1]
> > Finished installing GRASS 6.4.
> > Error2:
> > Warning messages:
> > 1: In getDependencies(pkgs, dependencies, available, lib) :
> >   package 'pkgDepTools' is not available
> > 2: In getDependencies(pkgs, dependencies, available, lib) :
> >   package 'Rgraphviz' is not available
> > > q()
> > Error3:
> > https://svn.osgeo.org/osgeo/livedvd/gisvm/branches/arramagong_2/doc/descriptions/maptiler_description.html:
> > 2009-10-09 19:16:33 ERROR 404: Not Found.
> > Note: Please do not shutdown testing vm.
> > We will wait for your feedback.
> > Regards
> > Aneel
> > On Mon, 2009-10-12 at 13:16 +0200, Eric Lemoine wrote:
> >> On Mon, Oct 12, 2009 at 12:24 PM, Cameron Shorter
> >> <cameron.shorter at lisasoft.com <mailto:cameron.shorter at lisasoft.com>> wrote:
> >> > Eric,
> >> > On the click2try VM, could you please:
> >> >  svn update install_mapfish.sh
> >> it looks like I don't have the permissions to svn upate
> >> install_mapfish.sh in /usr/loca/share/gisvm/bin. Were you thinking
> >> about something else?
> >> Thanks,
> >> >  sudo ./install_mapfish.sh 2&>1 tee /var/log/arramagong/install_mapfish.log
> >> >  # Verify that mapfish works
> >> > Eric Lemoine wrote:
> >> >> 2009/10/10 Cameron Shorter <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>>:
> >> >>> Tom tells me I can forward this email to the public live demo list now.
> >> >>> So
> >> >>> please reply to this list.
> >> >> Hi
> >> >> Mapfish isn't installed properly in the click2try virtual machine. The
> >> >> virtual machine was installed before Hamish did an important change to
> >> >> install_mapfish.sh it seems. What should we do?
> >> >> Thanks,
> >> > Cameron Shorter
> >> > Geospatial Solutions Manager
> >> > Tel: +61 (0)2 8570 5050
> >> > Mob: +61 (0)419 142 254
> >> > Think Globally, Fix Locally
> >> > Geospatial Solutions enhanced with Open Standards and Open Source
> >> > http://www.lisasoft.com
Regards
Aneel
More information about the Live-demo mailing list
