[Live-demo] Does your application work on the click2try GISVM?
Cameron Shorter cameron.shorter at lisasoft.com
Tue Oct 13 15:38:07 EDT 2009
I don't have access to the click2try image at the moment.
Can someone please help Eric out. I'm guessing that the password for
"user" has changed?
Is someone able to successfully run:
cd /home/user/gisvm/trunk
sudo svn update install_mapfish.sh
Eric Lemoine wrote:
> On Tue, Oct 13, 2009 at 11:52 AM, Cameron Shorter
> <cameron.shorter at lisasoft.com> wrote:
>> Eric,
>> You don't need to have your username in the suders file to run the sudo
>> command.
>> What should happen is that you are prompted for a password for
>> username=user. Enter the password for user, which="user".
> sorry, but it doesn't work. "user" isn't the correct password for
> username "user", correct password is "password". If I use "password" I
> get the following error message:
> "user is not in the sudoers file. This incident will be reported."
> what am I doing wrong?
> Thanks,
>> Eric Lemoine wrote:
>>> On Tue, Oct 13, 2009 at 8:52 AM, Cameron Shorter
>>>> Are you using username="user", password="user"?
>>> password="password"
>>>> Thinking about it, you probably need to run "svn update" as root as well
>>> you mean with "sudo" ? it doesn't work... as user "user" isn't in the
>>> sudoers file.
>>>> as
>>>> I think the original checkout is done by the bootstrap.sh when run as
>>>> root.
>>>> Eric Lemoine wrote:
>>>>> On Tue, Oct 13, 2009 at 8:17 AM, Cameron Shorter
>>>>>> I think I replied, but maybe my email was lost.
>>>>> I'm very sorry, I missed it.
>>>>>> On the vm, (typing from memory)
>>>>>> cd /home/user/gisvm/trunk/bin
>>>>> I don't have the permission for that command:
>>>>>> sudo ./install_mapfish.sh
>>>>> and I don't have permission for this one either.
>>>>> I'm logged in as "user".
>>>> Cameron Shorter
>>>> Geospatial Solutions Manager
>>>> Tel: +61 (0)2 8570 5050
>>>> Mob: +61 (0)419 142 254
>>>> Think Globally, Fix Locally
>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>> http://www.lisasoft.com
>> Cameron Shorter
Cameron Shorter
More information about the Live-demo mailing list
