[Live-demo] Does your application work on the click2try GISVM?
Cameron Shorter cameron.shorter at lisasoft.com
Tue Oct 13 16:36:22 EDT 2009
Tom,
It would be great if you could also try:
sudo ./install_mapfish.sh 2>&1 | tee /var/log/arramagon/install_mapfish.log
And send the install_mapfish.log back to this email list to verify that
it is ok.
Tom Callaghan wrote:
> Hi Cameron,
> Your access to the click2try instance named osgeo-gisvm20-25 at
> http://www.click2try.com should be working for you now.  When you LAUNCH the
> app, log in with the user name user, password user.  I also ran "sudo svn up
> install_mapfish.sh", provided the password "user", and the command appeared
> to function correctly.
> Tom
> -----Original Message-----
> From: live-demo-bounces at lists.osgeo.org
> [mailto:live-demo-bounces at lists.osgeo.org] On Behalf Of Cameron Shorter
> Sent: Tuesday, October 13, 2009 2:38 PM
> To: Eric Lemoine; live-demo at lists.osgeo.org
> Subject: Re: [Live-demo] Does your application work on the click2try GISVM?
> I don't have access to the click2try image at the moment.
> Can someone please help Eric out. I'm guessing that the password for
> "user" has changed?
> Is someone able to successfully run:
> cd /home/user/gisvm/trunk
> sudo svn update install_mapfish.sh
> Eric Lemoine wrote:
>> On Tue, Oct 13, 2009 at 11:52 AM, Cameron Shorter
>> <cameron.shorter at lisasoft.com> wrote:
>>> Eric,
>>> You don't need to have your username in the suders file to run the sudo
>>> command.
>>> What should happen is that you are prompted for a password for
>>> username=user. Enter the password for user, which="user".
>> sorry, but it doesn't work. "user" isn't the correct password for
>> username "user", correct password is "password". If I use "password" I
>> get the following error message:
>> "user is not in the sudoers file. This incident will be reported."
>> what am I doing wrong?
>> Thanks,
>>> Eric Lemoine wrote:
>>>> On Tue, Oct 13, 2009 at 8:52 AM, Cameron Shorter
>>>>> Are you using username="user", password="user"?
>>>> password="password"
>>>>> Thinking about it, you probably need to run "svn update" as root as
> well
>>>> you mean with "sudo" ? it doesn't work... as user "user" isn't in the
>>>> sudoers file.
>>>>> as
>>>>> I think the original checkout is done by the bootstrap.sh when run as
>>>>> root.
>>>>> Eric Lemoine wrote:
>>>>>> On Tue, Oct 13, 2009 at 8:17 AM, Cameron Shorter
>>>>>>> I think I replied, but maybe my email was lost.
>>>>>> I'm very sorry, I missed it.
>>>>>>> On the vm, (typing from memory)
>>>>>>> cd /home/user/gisvm/trunk/bin
>>>>>> I don't have the permission for that command:
>>>>>> and I don't have permission for this one either.
>>>>>> I'm logged in as "user".
>>>>> Cameron Shorter
>>>>> Geospatial Solutions Manager
>>>>> Tel: +61 (0)2 8570 5050
>>>>> Mob: +61 (0)419 142 254
>>>>> Think Globally, Fix Locally
>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>> http://www.lisasoft.com
>>> Cameron Shorter
Cameron Shorter
More information about the Live-demo mailing list
