[Live-demo] Does your application work on the click2try GISVM?
Cameron Shorter cameron.shorter at lisasoft.com
Tue Oct 13 18:15:10 EDT 2009
Dane,
Sounds like we may need to update our build scripts?
I suggest raising an issue in the issue tracker with the proposed
solution until it is fixed in the main build.
Dane Springmeyer wrote:
> On Oct 13, 2009, at 2:23 PM, Dane Springmeyer wrote:
>> On Oct 13, 2009, at 1:11 PM, Cameron Shorter wrote:
>>>> Pending issues:
>>>> Issue1:
>>>> Launching /usr/bin/mapnik_start_tilelite.sh
>>>> [TileLite Debug] --> Using mapfile:
>>>> '/usr/local/share/mapnik/demo/population.xml'
>>>> Traceback (most recent call last):
>>>> File "/usr/local/bin/liteserv.py", line 120, in <module>
>>>>   from tilelite import Server
>>>> File "/usr/local/lib/python2.6/dist-packages/tilelite.py", line
>>>> 12, in
>>>> <module>
>>>>   import mapnik
>>>> ImportError: No module named mapnik
>> Sorry I was not aware of this one previously...
>> Logging into the 'osgeo-gisvm20-25' machine now to take a closer
>> look...
> The problem is that only  'python-mapnik 0.5.1-3ubuntu2.0' is
> available via apt on the click2try machine.
> This is different from the livedemo iso which installs
> '0.5.1-3ubuntu2.1' (which includes python2.6 support and is needed for
> the demos to work)
> I tracked this down to the fact that the click2try machine does not
> have this line:
> deb <url> jaunty-updates main restricted universe # key here is
> 'jaunty-updates'
> in '/etc/apt/sources.list'
> Can this be added?
> Then an apt-get update/upgrade would be needed...
> Dane
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
