[Live-demo] Does your application work on the click2try GISVM?
Dane Springmeyer blake at hailmail.net
Tue Oct 13 18:52:06 EDT 2009
On Oct 13, 2009, at 3:43 PM, Tom Callaghan wrote:
> Hello Dane,
>> I tracked this down to the fact that the click2try machine does not
>> have this line:
>> deb <url> jaunty-updates main restricted universe # key here is
>> 'jaunty-updates'
>> in '/etc/apt/sources.list'
>> Can this be added?
>> Then an apt-get update/upgrade would be needed...
> The following are the contents of /etc/apt/sources.list:
> deb http://archive.ubuntu.com/ubuntu jaunty main universe multiverse
> deb http://archive.ubuntu.com/ubuntu jaunty-updates main universe
> multiverse
> It appears to have the jaunty-updates line, but with different
> options.  If
> this is not what you want, what line specifically do you need here?
I added that 'jaunty-updates' line just now.... I did not realize that
it would 'stick' in the running machine so others would see. Cool, (I
hope).
All that would need to be done from there is to run:
apt-get upgrade # which fails on some obscure error about python-dev
and dpkg for me (I tried it previously). Maybe because multiple users
are logged in currently?
Tom, can you try and see if it works for you?
Dane
More information about the Live-demo mailing list
