[Live-demo] Does your application work on the click2try GISVM?
Dane Springmeyer blake at hailmail.net
Wed Oct 14 14:38:45 EDT 2009
Just the 'apt-get upgrade' will bring in the right version of python-
mapnik, that make available the mapnik python bindings for python2.6
(they are already installed for python2.5).
So, not extra installation should be necessary, just updating the
system apps with apt.
This is because this was a bug in the ubuntu packaging and therefore
available via apt (even though mapnik was not upgraded):
https://bugs.launchpad.net/ubuntu/jaunty/+source/mapnik/+bug/354205
Dane
On Oct 14, 2009, at 11:28 AM, Alex Mandel wrote:
> What's the next step after that?
> apt-get install mapnik?
> or rerun
> sudo ./install_mapnik.sh?
> Alex
> Dane Springmeyer wrote:
>> Well, in whatever mode works for your system run:
>> apt-get update
>> apt-get upgrade
>> Until then the Mapnik package will not be installed/available and it
>> appears that I can't do anything to help.
>> Dane
>> On Oct 14, 2009, at 10:07 AM, arun.s at tecnics.com wrote:
>>> Hello Dane,
>>> Currently the running vm has (apt-get upgrade) latest packages
>>> upgraded. This upgrades is done on the 'base'  of virtual machine.
>>> In
>>> click2try vm , if something is applied on  'base' then that is
>>> present
>>> for running instance of vm.  You might see some 'numbers of pakage'
>>> still needs to be upgraded . Its because 'app' layer also has apt-
>>> get
>>> info (database) just like  'base' which misguides user. This
>>> misguiding information is something which we still need to work on
>>> and
>>> will be fixed soon.
>>> If you have observed something different or specific location then
>>> please share your thoughts. we will be happy to provide you more
>>> details.
>>> Now about error ,
>>> "dpkg: error processing gnome-power-manager (--remove):
>>> failed to delete `/etc.dpkg-tmp': read-only file system".
>>> Its because at present , if 'user' require to install any package
>>> using dpkg (or apt-get) , we require to run the vm in different mode
>>> (which is maintence mode where 'app' or base has write permission)
>>> rather then the one which its running for user mode.
>>> Does above information provides all information as expected ?
>>> Please reply in case you have more queries.
>>> Regards,
>>> Arun Sharma
>>> Click2try
>>> From: "Dane Springmeyer" <blake at hailmail.net>
>>> Sent: Wednesday, October 14, 2009 9:46 PM
>>> To: "Aneel" <aneel.r at tecnics.com>
>>> Subject: Re: [Live-demo] Does your application work on the click2try
>>> GISVM?
>>> On Oct 13, 2009, at 4:29 PM, Tom Callaghan wrote:
>>>> Hi Aneel and Arun,
>>>> Dane is requesting that we perform an apt-get upgrade. Since you
>>>> are
>>>> assembling all of this for production, I wanted to pass the request
>>>> on to
>>>> you. Apparently, our /etc/ap/sources.list file did not have an line
>>>> for
>>>> jaunty-updates. I was thinking that that would be best done in the
>>>> base
>>>> image, but do not know what the impact will be on the app layer.
>>> So the new line was added to the 'sources.list' but 'apt-get update'
>>> was not run on this new machine. Why not?
>>> I tried to do it myself within the running VM but after all packages
>>> are downloaded (took about 20 minutes) dpkg bails with this error:
>>> 'dpkg: error processing gnome-power-manager (--remove):
>>> Do you know why this is happening?
>>> Dane
More information about the Live-demo mailing list
