[Live-demo] Does your application work on the click2try GISVM?
Cameron Shorter cameron.shorter at lisasoft.com
Wed Oct 14 15:26:52 EDT 2009
Jeroen,
I hope that we can apply your fixes to the geonetwork install scripts.
If you have not updated the install_geonetwork.sh , can you please
describe the issue and fix in the issue tracker, so that we can update
it before we go through the next release cycle.
http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=priority
Jeroen Ticheler wrote:
> Hi Aneel,
> These are the changes I did:
> from the root of the geonetwork application:
> sudo chown -R user:user *
> In the shortcuts that start and stop GeoNetwork I removed the first
> part of the command, just leaving the part:
> /usr/lib/geonetwork/bin/start-geonetwork.sh
> or
> /usr/lib/geonetwork/bin/stop-geonetwork.sh
> That's all.
> Ciao,
> Jeroen
> ____________________________________________________
> Jeroen Ticheler
> De Braakweg 12a
> 7524 PH Enschede
> Tel/Fax: +31 (0)53 7370049
> Mobile: +31 (0)6 81286572
> http://www.ticheler.net
> Please consider the environment before printing this email.
> On Oct 14, 2009, at 1:11 PM, Aneel wrote:
>> Hello Jeroen,
>> Please give us the steps you did to fix these issues. Whatever you doing
>> is specific to particular instance only. We have to fix them at
>> application level to make permanent.
>> Regards
>> Aneel
>> click2try
>> On Wed, 2009-10-14 at 13:05 +0200, Jeroen Ticheler wrote:
>>> Last thing, I also fixed the start and stop shortcuts. They should
>>> point directly to the start and stop scripts and not go through the
>>> launchhelper script.
>>> Greetings,
>>> Jeroen
>>> On Oct 14, 2009, at 12:46 PM, Aneel wrote:
>>>> Hello Jeroen,
>>>> Maintenance and bug fix activity is going on click2try-GISVM. Please
>>>> don't try the GISVM on click2try for some time. Once we have done with
>>>> maintenance activity, we will post update on this mailing list.
>>>> Regards
>>>> Aneel
>>>> click2try
>>>> On Wed, 2009-10-14 at 12:41 +0200, Jeroen Ticheler wrote:
>>>>> Hi Tom,
>>>>> I tried again several times today. I got some steps further, but
>>>>> can't
>>>>> get on to the desktop :-( I use "user/user" as account/pw but then I
>>>>> get an error as shown on the screenshot. Is there a way to use SSH?
>>>>> Kind regards,
>>>>> Jeroen
>>>>> Jeroen Ticheler
>>>>> De Braakweg 12a
>>>>> 7524 PH Enschede
>>>>> On Oct 14, 2009, at 1:22 AM, Tom Callaghan wrote:
>>>>>> Hi Jaroen,
>>>>>> Maybe I can help you with your connection issues.  The message
>>>>>> “Public Internet Access: Yes, Not available” refers to something
>>>>>> that has not yet been set up for this VM.  This is not a problem and
>>>>>> you should still be able to access the VM.  When you attempted to
>>>>>> connect, had  you highlighted the VM osgeo-gisvm20-25 and click2ed
>>>>>> the LAUNCH button?  If so, what happens?  Do you see a light purple
>>>>>> screen with a progress bar across the top?  Do you receive a message
>>>>>> for installing a click2try java applet?  Does a frame with a page
>>>>>> not found appear on the left side of the screen with a title bar
>>>>>> “quickstart guide”?
>>>>>> Tom
>>>>>> From: Jeroen Ticheler [mailto:Jeroen at Ticheler.net]
>>>>>> Sent: Tuesday, October 13, 2009 5:41 PM
>>>>>> To: Aneel
>>>>>> Cc: Cameron Shorter; Ricardo Pinho; Tom Callaghan; Arun Sharma
>>>>>> Tecnics
>>>>>> Subject: Re: [Live-demo] Does your application work on the click2try
>>>>>> GISVM?
>>>>>> Hi Aneel,
>>>>>> I tried to connect and have a look. I can't get access, maybe
>>>>>> because someone else is using the VM, is that correct? I read
>>>>>> "Public Internet Access: Yes, Not available" and I see one user
>>>>>> online.
>>>>>> Concerning the problem, the first two lines are normal for a very
>>>>>> first time startup. The following three lines are not and indicate
>>>>>> that the permissions of the account running the application don't
>>>>>> allow writing to the logs directory. Most likely the same is true
>>>>>> for some other directories that GeoNetwork needs to be able to write
>>>>>> to. I suggest reviewing the privileges of the process owner to
>>>>>> ensure that write privileges are given to the GeoNetwork application
>>>>>> folders.
>>>>>> Let me know if I can help further.
>>>>>> Kind regards,
>>>>>> Jeroen
>>>>>> ps. I will be on my way to Sydney from Thursday morning onwards
>>>>>> (Amsterdam time zone).
>>>>>> On Oct 13, 2009, at 8:54 PM, Aneel wrote:
>>>>>> Issue2: (GeoNetwork - it doesn't work)
>>>>>> Launching /usr/lib/geonetwork/bin/start-geonetwork.sh
>>>>>> rm: cannot remove `logs/*request.log*': No such file or directory
>>>>>> rm: cannot remove `logs/output.log': No such file or directory
>>>>>> mv: cannot stat `logs/geonetwork.log.*': No such file or directory
>>>>>> mv: cannot stat `logs/intermap.log.*': No such file or directory
>>>>>> mv: cannot stat `logs/geoserver.log.*': No such file or directory
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
